Replacing fuel lines
Started by silversport, November 13, 2021, 08:47:21 PM
silversport
On an 8V 71 in an 4106,  I need/should to replace the fuel lines. What am I looking for? There is a lot of choices out there.
1962-GM-4106
richard5933
Assuming that the current hoses are in place and the correct ones, the simplest way to replace them is to take then to a shop that makes hoses and have them make a new set just like the old. Every town that has truck repair shops will have at least one of these hose shops.
Cloth covered  low pressure ,hose shops usually sell you high pressure rubber coated hose hard to work with then they crack,If you have the OEM  Aeroquip hose just buy the hose stock and make your own the fitting are reusable and easy to work with  that is why they used Aeroquip  150psi working pressure is more than you need for a 70psi system,Stainless low pressure covered silicone hoses are real nice but they come at a high price   good luck
dtcerrato
What Luvrbus said... And the ends are solid brass & serviceable over & over - not throw away. After 42 years of same bus ownership this is a subject near & dear to our maintenance schedule. BTDT over & over with the same gold ends. :^
Dan & Sandy
North Central Florida
PD4104-129 since 1979
Bill Gerrie
Dan
I have used nothing but the replaceable hose ends for years but never seen brass ones. Mine are steel.
Quote from: Bill Gerrie on November 14, 2021, 05:47:47 AM
Dan
Dans are collectable lol I run across a few brass Aeroquip fitting not many anymore except on old marine engines,you can still buy those in stainless from Parker for  a price
dtcerrato
Bill we have a couple steel ended hoses but most are "red" brass - the highest quality with more copper content according to the scrappers
Luvrbus - BINGO!  I just realized why most of our hose ends are brass! Our 53 has a 69 Grey Marine engine. You were the one that gave me the clue on why I couldn't find a DD serial number during our rebuild. Lol
Dan & Sandy
Utahclaimjumper
Years ago I replaced all the fuel lines on my "62" 06,, They were run along the curb side wall and a bear to get to..  I replaced all with lengths of pre-made steel brake line that I pieced together as I went along the line..  Most of the old line had rusted thru from the inside out.. That was in 1980 and the same lines are still in service..>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
windtrader
Quote from: silversport on November 13, 2021, 08:47:21 PM
What gives you the idea the fuel lines need replacing in the first place? Everything on these buses mostly looks old, just curious how one knows when lines are just aged but got life in them? Personally, I've got a list of parts I know need work and no desire to add more to the fix-it list. lol
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Lines have hardened, seeping fuel, outer jacket decaying and got some visible perishing . The usual list for rubber products.
And, when you have a "finished" bus, you need to find something else to "catch-up" next... no work on the bus makes the busnut grumpy?
Happy coaching!
Buswarrior
Some hoses get harden then with no flex they crack the fitting on both the fuel and oil lines lol hoses are a lot easier to replace than some of the damn fittings
Tedsoldbus
Yikes! At first I was with wind trader. I've had my bus just a year now. I have changed two badly cracked ratty looking heater hoses that got cooked in the engine box area and it was amazing to watch the new ones get made as described above. Just take them the old one, tell them what it is, and very fun to be handed a brandy new one to put back on. But I got a bit frightened when I see all the salty guys talk like they change fuel lines all the time!!?? I've also wondered about my wheel bearings. Two old guys told me if it they ain't leaking don't mess with them. Another said do it after so many miles?? I change oil and fuel filters probably more than I need to, but fuel lines? Checking what mine are made of is I guess is a good start.
1980 shorty (35') Prevost
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
Some change lines every 5 years some wait till one leaks or goes on the highway, any hose is exspensive now, radiator hose sell by the inch now buying by the foot is a thing of the past unless you have deep pockets
Tedsoldbus
So do they get gummed up or is changing just preventative? Any advice on wheel bearings?
6V92  HT 740
Lake Nottely Ga
Bus name "debt"
richard5933
Quote from: Tedsoldbus on November 15, 2021, 02:07:30 PM
They get dried out, stiff, and start to crack. They can also collapse on the inside, but that doesn't seem as common.
Wheel bearings? Have you got any idea when they were last serviced?
