Axle End Front Axle & Tag Axle
Started by Nineforever, April 24, 2014, 04:32:29 AM
Nineforever
What type of oil should i be using for the front Axle & Tag Axle  .... i have been using sae 40 wt
Dave
Hyway 3 100 klms south of Yellowknife NWT Canada
40w is the recommendation on the O1 lube chart for the MCI go with it the same spec as the engine oil
Boomer
I use PowerPunch, have for 40 years.  Comes in handy quart bottle.
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
Nineforever
Ok thanks stick with what i'm  using sae 40 wt ................ just changed hub caps front and rear before i filled them i thought i should ask ... i guess when its minus - 40 it must be just like lard in there under the hub cap
wg4t50
Seems to vary, my MC7 manual said same as engine, 30 wt.  i wound up using Lucas Hub Oil and loved it. Tried the 85W-90 gear oil but changed to the Lucas, temps went down, no more issues.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
