Williams air throttle part - Ebay?
Started by Paladin, October 02, 2012, 07:25:30 PM
Paladin
'75 MC-8   'Event Horizon'
8V71  HT740
Salt Lake City, Utah
Eagle Andy
That is a good start go for it  ;D I had to make  my bracket the is on that one.you will love it when you get it done.
That is a universal control you need the pedal to match fwiw Andy is good at installing those he did it right the 1st time
Eagle Andy
Yes Clifford I did do it right the first time  ;D However I had you to thank  for that.  ::)
Cary and Don
Make sure that the pedal and the control BOTH have the same air pressure rating.  If not you will either have no throttle or a wide open throttle during application.  The part number on the housing will tell you. Experience speaking here.
Don and Cary
1973 05 Eagle
Neoplan AN340
It really is the best to buy the control that is made for the DD 2 strokes it mounts on top of the governor housing no brackets to make or linkage to figure out fwiw
Gary LaBombard
Don,
I just received a Williams Air Control foot treadle with the numbers (WM-453-B) on the body.  Two weeks ago I purchased the ebay listing of the modulator I will call it that mounts at the engine that is also mentioned in this thread above.  This is a very, very good looking modulator too I might add and the price is wonderful too.  I plan to get another just for kicks or in case needed on the road and have a spare for the price. The instructions for the modulator mounted on the engine says to use (60 psi) but I do not have any instructions for the foot treadle I just received today.  With the knowledge you now have in your opinion should I use a pressure regulator for 60 psi or use the full pressure to have control of the foot pedal for speed of the engine etc?  so with the information I have given you, would you recommend full air pressure of the 1/4" line or 60 PSI??  Also, would you run 3/8" or 1/4" line from the front of the bus to the back Governor modulator??
Thanks ahead of time
Gary
Gary
Better check it out for clearance Gary sometimes they work on a 05 without and modifications above the panel sometimes it takes a little fab work lol
Bottom
