two air valves on throttle??????
Started by mccarlk, October 19, 2008, 04:46:27 PM
mccarlk
hi on the housing there is the throttle lever and then there is 2 air valve , is one fast idle and the other is fuel shut off?, if so what is the measurement between the end of the valve, and the levers, with no air applied, thanks
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
