Tattle-Trail towing monitor
Started by luvrbus, September 03, 2008, 09:24:30 PM
Any of you guys know anything thing about this system   www.tattle-trail.com  I have a tire monitor on the Jeep but a drive line came out and the tire system did not do anything.I was looking for something better. comments please
Hi Luvrbus,
It seems mearly a motion/vibration sensor that will transmit when alarmed, to the driver.
I wonder how many times it would go off on a bumpy road, or small bump? Could be anoying...??
JackConrad
You said "a drive line came out".  Since we also tow a Jeep, I would like more details.  Thanks, Jack
Blacksheep
Sounds like a broken U-joint to me or a driveshaft was being removed and wasn't completed!
Ace
Jack, on or 5600 mile trip this summer towing the Jeep I had a bearing in the transfer case fail causing the driveline failure after the bill from Jeep I look very close under it to see if there is oil leaking anywhere.First time I had a problem and been towing Jeeps for years
JackConrad
Quote from: luvrbus on September 04, 2008, 08:14:18 AM
Thanks, I will add that quick look under the Jeep to our pre-trip list.  Jack
