ELECTRIC SOLENOID ON SIDE OF TRANS
Started by mccarlk, August 11, 2008, 05:24:27 PM
mccarlk
hi i have a electric valve (SOLENOID) mounted on the side of my 644 it looks to be aftermarket, it has three  5/16 lines on it and a ground wire and a trigger wire , any ideas?
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
makemineatwostroke
yep it for lock up of the torque converter in 1st and 2nd gear it is automatic in 3rd and 4th gear
mccarlk
JackConrad
    If it is a torque converter lock-up solenoid, wire it to a switch on the dash. BUT, remember to switch it off when coming to a stop or you will stop the engine. They are usually only used in hills to help prevent overheating and better engine braking on the downhill side.  Jack
