Leaving the driver's heat...
Started by Danny, April 06, 2006, 08:54:44 PM
Danny
I want to remove the bus heat and air from the bus - but leave the driver's heat and defroster.  What precautions should I be aware of in doing this.  I don't want to remove more than I should... ???
Danny
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
The main thing you want to do is to make sure the radiator lines are intact after you remove the big system.  I personally did this and used a ball valve to control the heat at the driver's seat and installed a toggle for the electric water pump in case it needed help.  But so far the engine water pump is enough to circulate the water through the lines just fine.   Good Luck, TomC
Danny
