My Bus heater story
My Bus heater story
Started by pipes, June 04, 2008, 10:58:39 PM
pipes
 just finished (Almost) installing a new big heater in the drivers area (using the (The heater  engine water)  Built a simple encloser that allows me to use the heater in many ways via 2 flapper doors + the existing control of four  2 inch defroster  outlets.
  I can>.
Heat the bus the normal way
Discharge 100% of the engine HEAT overboard ( from the heater ) via a 3 inch ABS  pipe (Capped when not in use) behind the  front bumper on a hot pull/day, without any heat IN the bus.
Suck the air OUT of the bus to overboard.
suck outside air INTO the bus (with water On/off )..
Blow 100 % hot air to the defroster
Also from one of the defroster outlets put hot/cold air to the drivers feet thru a small partision
next to my right leg ...with a cap, on or off as needed..
Three of the defrosters used one to spare !!!!! BTW it blows a lot air....I have a feeling that I missed another action
Stanwood WA.. North of Seattle.
05 Eagle plus air bags.
pvcces
Ken, didn't you already have your coach heat set up so that you could blow it overboard if you wanted to?
Do you have any pictures?
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
pipes
Hi TOM''''''
Yes Sir, I built the steel parts years ago. I just built a box under the heater to contain the direction of  the air flow to the in/out flaps, plus had to hitch it to the water lines and some other minor modifications.
                                               It works as planned and to look at it looks like a plain ole heater.
A couple weeks ago I was doing some stick welding  close to heater, the 3 wires to it were laying on the second step as was I, with the ends stripped I plunked the rod holder on the step then my foot knocked it to the wires and mated to the med speed wire I thought it was a turbo prop airplane was after me!!!!I It must have been turning umteen thou  RPM
                                                    It melted the med resistor and one impellor spun off the shaft, I fixed it and put a rheostat on it, one wire and it runs just fine....
PS......... I have sorted out which is which on the plumbing ...........From previous post
Tom Y
I would like to see pics to.  Sounds intresting.  Tom Y
Tom Yaegle
busnut104
I did the same on my MC8, I used the org. big bus heater, in the winter I use it as intended and in the summer cap it off and it is exhausted to the side, adds a lot of extra eng.cooling if needed.
I would like to see some pics also. That sounds like a great idea. Although the bus heater I'm using took the place of the original. Would be nice to be able to cap it off and send it down and out.
pipes
Hi Guys........... Pictures won't help much by them selves. I have a fiend coming here Sunday to take pictures and make drawings of the mechanics of operations.
                                               This combination should make it understandable.......................
HANG IN THERE .....................BTW..My Gen exhaust goes up thru the roof.  KEN
superpickle
Quote from: pipes on June 07, 2008, 10:34:36 AM
Stay away from them Fiends, theyer Dangerous..  :-[
Support Global Warming:
Drive an SUV.
pipes
Both flaps DOWN  = normal bus heating
pipes
bottom flap UP-upper flap DOWN = drawing outside air into bus ... The middle plywood panel will be permanent The intake is deep down in the stair well the coldest area !!
pipes
bottom flap UP -upper flap UP = drawing in 100% outside air in then discharging overboard To help cool the engine.
pipes
pipes
Just to show ABS connection
pipes
pipes
Hi ...A friend posted the pictures for me .... I will be back later to try and explain the operation ... Ken
