old tires
Started by tekebird, May 09, 2008, 07:19:56 AM
WEC4104
I followed the posted link and it played a news story about a sink hole in Texas.  The message title said "old tires".  Is that what they are supposed to fill the hole with?
tekebird
guess it defualts to the lead story......on the right side scroll down through the stores
HighTechRedneck
superpickle
My tires are Koreian and the DOT numbers are a bit different.. theres a small ovel with (5005)and (4905) I assume it means 50th week of 05
etc ?  2 of the tires have NO code numbers after the Dot and a few letters  ??? ??? ???
Bought them about 7 months ago.. ???
Support Global Warming:
Drive an SUV.
Sometimes the DOT numbers and build dates are only on one side of the tire-check the inside of the tires.  Good Luck, TomC
Lin
Only vaguely related.  I just went up to Santa Cruz and brought my other bus, the 67 Superior down south.  Before taking it, I had my mechanic there look it over and make sure it was ready for a 500 mile trip.  It really has not been on a trip in years.  He greased it, topped off the fluids, checked around and said everything looked okay, but that I should change the outer, left, rear tire since it had a lot the cracking, and he doubted its integrity.  I switched it out with the spare.  When I got it off, it turned out that there was a serious, deep split going completely across the tread.  That tire would have been guaranteed to come apart on the road.  Except for it being a bit jagged, it almost looks like it has been cut.
