Valve Cover Gasket on 8V71
Started by Fredward, April 19, 2008, 10:39:35 AM
Fredward
After we ran the rack on my 8V71, I've had trouble getting the drivers side valve cover to seal. Tightening it real tite seems to help but it still leaks oil in one corner. Should I just get a new rubber gasket for it? Under physical inspection; it looks OK.
Or is there a trick?
Fred Thomson
JackConrad
Are your valve covers cast aluminum or stamped steel.  The take a  gasket.  If it is a steel cover, it could be bent/warped.  Jack
Stan
In the 1930s Chevrolet came out with a valve in head engine and the valve covers leaked oil. Nothing much has changed. A tin cover on a cast head changes shape at different rates with temperature change.
