TRICO Air WW Valve
Started by gus, March 03, 2008, 06:53:27 PM
I got such good results on the lock strip question now I'll try another one.
My air WW control valves leak slightly. I took one apart and saw that the problem is the small plastic disc with grooves and holes to route air to the proper places. The disc is slightly worn and allI need is one of those discs or a valve repair kit.
I've googled my brains out with negative results. Anyone have any ideas about where I can get these parts? The part number for the valve appears to be F-1430 and the disc is F-1442. It is made by the TRICO company which has been in the WW business for many years but I found nothing on their website except blades and arms.
Gus,aren't they called Trico/Folberth wipers
wildbob24
Gus,
I haven't used these guys yet, but have heard good things about them. You might give them a shout:
http://www.rometruckparts.com/
P8M4905A-1308, 8V71 w/V730
Custom Coach Conversion
PD4106-2546, 8V71, 4sp
Greenville, GA
Gus,
Ours leak also. Don't know the maker but I will follow your thread to learn more. I'm in CA right now so can't go find out.
Good Luck,
Sojourner
Trico is now own by Stant Corp. Their website is down for now...for how long...????
Here a link to service & repair of UK version that from railcar manual:
http://www.railcar.co.uk/mechanical/wipers/trico/service.htm
Have you been to NAPA nearest store? They have heavy duty truck catalog to locate your parts if it still available.
Rome Truck advertise air wiper parts. Their requesting site is out of order for now???
I sent a e-mail in regard a online catalog or whatever available to obtain air control valve & motor parts.
FWIW
Sojourn for Christ, Jerry
gmbusguy1
GmBusGuy.com has the replacement air wiper motors new for 250.00 each and that includes a new valve
FWIW
Chris
My motors are fine, it is only the leaky valve that is a problem.
Where do you find parts?
Do you overhaul the motors and valves?
