finally my shower has tile!!
Started by H3Jim, February 12, 2008, 06:07:38 PM
H3Jim
After over a year of fooling around with other things, and doing wiring and plumbing behind the walls, I have tiled my shower.  I have been using visqueen tacked up to the ceiling, and its not fun taking a shower in the middle of it.  while I am ordering reeded glass door and return, I will be using a regular shower curtain this weekend.  Finally.  Feels very good to be done with another project, especially one so important to creature comfort.
Here is a pic.  The rest of the bus has royal blue accents - lights, bath sink, drawer handles etc.  So that tile kind of goes with the rest of the bus.
Jim Stewart
NJT5047
Very nice!  Cool lighting too.  Are the lights LED or Halogen...or something else?
Looks like you've copied my 'headliner!'    ;)
JR
JR Lynch , Charlotte, NC
Ayn Rand
H3Jim
chinese LED's from ebay, all together they draw about .2 amp
They are not very bright, hopefully no reflection on the owner, but its enough to see.  The fuse panel I have them hooked up to has a small indicator light when a fuse is blown.  If I unplug the fuse, there is enough current going through the small light, that all 7 of these will light, although more dimly.  I am using this feature as a night light.  After leaving them on all night, I can't really tell any difference in house battery state of charge.
Yes, my entire bus still has this classy plywood ceiling.  I need to do drawers or even heat next.
Jim Stewart
gumpy
Consider leaving the shower curtain in place and skip the glass door. A couple reasons. First, you can leave it open and the shower dries nicely. Second when it's open it gives the impression that the whole room is bigger.  Boat supply sells a nice bendable shower curtain track that works great.
craig
Great job! You have a good eye.
I remember when I took my first shower in our Eagle after I completed ours, it sure felt good, and I smelled better too! Ours is not quite so fancy, but it works. I'm sure you will be happy when you can check it off your list.
Keep on keepin' on Jim,
Be safe,
Hi Jim,
Nice Job!
I tried some LED's in my ceiling pucks and I didn't like the lighting that they put out so, I put the halogens back in.
It looked like the LED's put out about a 1/4 of the light that halogens did..
jackhartjr
Nick, how long ago did you try the LED's?
The reason I ask is that over the last year or so they have improved them a lot, they seem to be getting brighter...and they are now getting them to where they spread the light better...as opposed to just kind of shining in a spotlight sort of way.
For what it's worth!
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
buddydawg
Job well done!  I need to quit hanging out here and actually get to working on mine!
1972 GMC T6H-5308A #024
1984 Eagle Model 10
Brandon Stewart - Martinez, GA
John Z
Very nice looking shower! I had to chuckle at the visqueen remark. I have not showered in visqueen since doing monitoring on asbestos abatement jobs, in the makeshift decontamination showers on the job site. This might motivate me to move my shower renovation up on the to-do list. I like your choice of lights,,, can't beat that almost non-existant current draw, and i am not a fan all the heat put out by the halogens.
www.silverbrook-mn.com
H3Jim
thanks all.
NIck, I don't really like the light put out by these LED's either, its a very cold blue light, and I used 7, but still its fairly dim. For the shower, all that is ok.  Although I have several more, I think I will stick with other kinds of bulbs for my other lighing needs for now.
Jack, yes LEDs keep getting better all the time, they are definitely  worth watching and trying because of their incredible efficiency.  These I bought over a year ago, but since I had them, I used them.
Jim Stewart
skipn
Jim,
    Very nice!
What did you use for backer board.....to reduce flex, vibration, swelling and shrinkage?
  or is that not an issue?
Skip
H3Jim
Skip,
We'll see if its an issue or not.  the right wall has studs to hide the plumbing, so I used 1/2 inch hardiebacker board.
The left side has 1/2 birch plywood over a wood frame, so I used 1/4 on that side. I"m headed to the desert this weekend, so if thre is still tile on the walls when I come back I'll be happy.
Generally, a lot of people have used tile in their buses with no ill affect, so I am optimistic.
Jim Stewart
JackConrad
Jim,
  When we did our shower, we made the walls with 3/4 oak furniture grade plywood covered with several layers of fiberglass cloth (matte in corners) and ployester resin. after it set up. we scuffed the fiberglass surface with a grinder and installed wall ceramic tile using standard wall tile adhesive and  non saned grout mixed with latex admixture. About 7 years and 35,000 miles since installation and no problems so far. this includes several trips through some rough terrain in cow pastures at Bluegrass music Festivals.  Jack
Quote from: jackhartjr on February 13, 2008, 04:05:42 AM
Jack
Hi Jack,
This was 2 weeks ago when I installed the LED's The bulbs pictured [above top] cost me over 20 bucks each..  Anybody want 8 of them??....
lloyd
I was wondering about how the tile and grout would handle the travelling up and down the road, but from what I am reading it seems to be staying on the wall. What did you us to attach the tile, normal thin set? My wife has always talked about inistalling a ceramic tile shower, so maybe I can make one of her wishes come true,lol.
