furnace ducts under cabinets in short toe kick
Started by Tenor, January 30, 2008, 11:32:36 AM
Tenor
Because our cabinets will go under under the side windows, they will be shorter than usual.  To help make up the lost space, I plan to make shorter toe-kicks.  Has anyone found a source for rectangular ductwork to fit in there?  Or has anyone come up with a different souloution?  Thanks!
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
paulcjhastings
HVAC sheet metal shop will make ducts of almost any size you want.
Paul Hastings
1993 Setra 215 w/ Detroit Series 60 & Allison HT748
Belle Plaine, MN
612-987-6021cel
John Z
Well, depending on what size of a toe kick you are making you may be able to use regular wall stack. I think it is only about 2 1/2" thick.
www.silverbrook-mn.com
Reddog
I saw a guy make ducting out of rain gutter downspout material (metal, not plastic). Kinda hillbilly, but readily available and worked out well.
Doug Engel, Gunnison, CO
"If people don't stare and point as you drive by, keep working."
HB of CJ
How's your lower back?  Mine sucks.  We are planning on having the base cabinets two (2) to four (4) inches taller than normal sossss we do not have to bend over at the waist.  Hate getting old.  Of course the higher base cabinets will block the bottom of the side windows.  Oh well.  Putting the heat ducts in the base cabinet bottoms is a great idea...plus it will keep your toes warm on a cold morning.  :) :) :)
Tenor
Well, since my wife and I could be considered low riders, (I'm 5', she's 5'4),  I don't think we'll have a problem.  That's also why I never plan do do a roof raise!
Glenn Williams
Lansing, MI
2001 MCI D4500
4 speed Spicer
I made my kitchen counter standard height since I am 6'3".  The counter tops do extend higher than the bottom of the windows, and my upper cabinets in the kitchen also extend well down into the window area, but believe me, it works!  I kept the original big windows of the transit which are all the same size for uniformity, just eliminated the blocked windows, but the windows in the kitchen are partially blocked, you can't tell from the outside.  Good Luck, TomC
Also-I made the toe kick 6 inches to facilitate the duct work for the furnace.  Good Luck, TomC
Tenor
My windows are rv type and slide open foreward, so I'd be building over my screens.
Glenn Williams
Lansing, MI
2001 MCI D4500
4 speed Spicer
My windows are RV type too (Peninsula).  Just keep a 2" gap utilizing a rear back splash on the counter top and it'll be fine.  Highly recommend you NOT build the counter tops short.  Good Luck, TomC
