643 flex plate?
Started by glang, May 31, 2006, 04:12:00 PM
glang
Anyone know if a 643 allision takes the same flex plate as a 740? I need a flex plate to fit an 8V71. Hoping to put the 643 in a MCI5 for a friend if we can get the right parts.
Gary
I don't believe so-different sized torque converters.  Although, the five speed version MT655 did have a larger torque converter for higher horsepower.  I would call Allison since the MT643 is still a widely used trans.  The HT740 is by far the superior trans (if you can fit it).  The MT643 gets torque converter lockup in the upper end of 3rd and all of 4th.  Whereas the HT740 locks up in the upper end of 2nd (can get lockup in 1st if you pull the gear shift lever to first) and in 3rd and 4th.  Good Luck, TomC
glang
I have a 740 in my Prevost but the 740 is to long for an easy hookup in the MCI5. The 643 is 31.5" verses the 740 at 37.5.
Thanks for input
Gary
Tom Y
Glang, I bought some used Allison parts from a place that is all they do. USA Parts 800-USA-7899, They are in Missouri.  They were helpful with me and had good prices.  Goodluck Tom Y
Tom Yaegle
