Air steps
Air steps
Started by Tom Y, January 03, 2008, 07:09:52 PM
Tom Y
I am looking to put a step on my bus. I have an electric step with a bad control and a little banged up. Also a MCI air step banged up also. Do any of you guys have an air step? Mine is air presure out and air pres in, no spring. If the air bleeds off is the step still solid or does it get shaky? Thanks Tom Y
Tom Yaegle
white-eagle
tom,
i have an air step that comes out when the switch is in the out position and the bus is in idle.  stop the engine and the step goes in, put it in gear and the step goes in, turn the switch back off and the step goes in.
when the bus is off and air down, the step gradually comes out and stays good enough to us.  when i get time (yeah, right) i'm going to reverse it's use and make it go out when the switch is on and bus not in gear.
Tom
Hi Tom,
When my bus airs down, the step comes out and it is sturdy enough that it won't move at all when stepped on.
While the bus is running, the step retracts when the door closes or when put into gear.
Hope this helps
makemineatwostroke
Tom,from reading the posts about air steps it looks like they are all different in operation mine works off the parking brake with a cylinder that looks like a brake pod mounted on the chassis with a short linkage to the step no springs has a switch to keep from going out if you choose ( parking brake on step is out )( brake off step in)  and it is always stays sturdy with no air pressure  made by a aircraft co in Chicago FWIW  (model 15 Eagle)
