Whos makes custom windows besides Peninsula?
Started by belfert, May 26, 2006, 03:40:43 PM
Peninsula is 6 to 8 weeks out on production right now.  Does anyone else make custom windows for RVs likes Peninsula does?
Brian Elfert
phil4501
CRL in L.A.  makes RV windows to your spec but I have never seen any of thier insulated glass units. 1-800-421-6144 is thier number. I just talked to them and they don't make dual glaze rv windows. Ther turn around time is 3 weeks. That means 4 weeks, they are a week late on everything I special order from them. They are inexpensive but I think you would be happier with Peninsula.
   I hope your still not sitting there with a broken window, you can have one made for less than $10 per square foot. Tell me what city you are in or near and I will tell you where to go. If any of my wholesalers have a plant near you, you can pick it up and pay them my cost.
Unfortunately, CRL only sells through glass shops.  Probably a bit too much hassle.
My friend and I are going to go over the floor plan and schedule this weekend.  6 to 8 weeks may not end up being too long for the windows.  Our goal is to have generator and air conditioners at minimum in a month so we can go to Amarillo, TX over July 4th.  If all we have is basically an air conditioned sleeping and gathering space by then, we may just stay in a hotel instead for probably less money.
Brian Elfert
phil4501
I am a glass shop. If you want, you can order from them with my ok. See the edited previous post.
rv_safetyman
I got my widows from Storm-Tite in Winnipeg.  Their website is:  http://storm-tite.com/.
They made them to my dimensions.  I had them do four windows to fit the Eagle openings and two windows for the door/driver's opening.
They were double pane and tinted.  I have been pleased with the quality.
Jim Shepherd
Evergreen, CO
Quote from: phil4501 on May 26, 2006, 04:23:00 PM
Yes, my window is still broken.  Four reasons why not fixed yet:
1. Nice hole for getting stuff out of bus.
2. I have decided to cover windows so may not need to repair.
3. I am seriously considering Peninsula or other windows to replace the ones I don't cover.
4. Lack of time.  I will have time while bus is in shop for a week as soon as MCI ever ships my brake parts.
I am in the Minneapolis, Minnesota metro area.
Brian Elfert
Quote from: rv_safetyman on May 26, 2006, 05:18:01 PM
I am curious on the approximate windows sizes ad how much they charged you?
I better get back out to the bus now that I've cooled off a bit.
Brian Elfert
phil4501
I thought your bus was in use now, I see that you are converting. I didn't mean to be as sarcastic as it looks in print.
I would likie to hear more about the storm-tites
dwbruner
The previous owner installed Storm-Tite windows in my '85 Eagle.  They are double-pane, tinted slider windows and seem to work well with no leaks :).  I do need new screens :(, but that is due to the previous owner accidentally destroying them while they were off for cleaning.
Darrin Bruner
1985 Eagle Model 10
gumpy
I installed Storm Tite's also. Good quality. Only a couple issues I'd do differently.
First, I would not install a plain, non-slider over 3 foot long. The 4 footers I put in have a problem in that the two panes of glass can actually touch each other in the center. There must be a tint film or something inside that has become spotted from this and is now visible and impossible to clean or clear. I don't see this problem on the sliders, only the fixed, non-sliders.
Second, their inner ring screws go into a channel that is kind of hokey and is very easy to strip. Solid aluminum instead of channel would have been better. I've had to up-size some of the screws.
Third, they only make one radius for corners - 3". If your old windows are not that radius, you'll have to do something to work around it. If you are skinning the windows and cutting new holes, it doesn't matter.
Fourth, the drip channel is not sealed very well, and I've had problems with leaking on a couple windows. One I've fixed. On the other one, the fix didn't seem to take so I'll be trying it again.
Other than that, I'm pleased with them. Note that if you elect to go get them, as I did (and another friend), you'll find out that the US Customs will report you to your state of residence, and in a couple years, they'll send you a bill for the sales taxes you didn't pay, plus interest and penalties!  Wonderful thing, our Government. You can't buy the product in the state, but by golly they'll collect taxes from you if you go elsewhere to purchase them! And their 2 year delay assures them they'll get even more of your money.
H3Jim
Thats a long way out for production for Penninsula.  when i ordered mine, i showed up and let them measure, then went back 3 days later and they had all 16 windows made. (two up, times 8 windows).  They must be working on a big order of some kind.  did they say if it will always be that long?
Jim Stewart
Ross
Quote from: H3Jim on May 30, 2006, 04:49:05 PM
Maybe that's because you were parked on thier doorstep.  I got mine 3 years ago and they took 6 weeks.  You probably got "while you wait" service.  If I drove ther to have windows installed at thier facility, I'd expect that sort of service.
They said the wait varies depending on number of orders.  Sometimes it can be only a week during slow times.  They have 1,600 windows on order right now.
I hope to make my window decision by the end of the week.  I am going to get a price for Hehr windows since I may be able to reuse some existing windows.  Hehr made the windows in the bus originally and should be able to supply replacement glass.
If not Hehr, I will go with Peninsula since nobody can beat their price yet.
Brian Elfert
Quote from: gumpy on May 30, 2006, 11:29:48 AM
This seems to be pretty standard on windows so they don't have to drill holes for each screws.  My Hehr windows are the same way.
QuoteOther than that, I'm pleased with them. Note that if you elect to go get them, as I did (and another friend), you'll find out that the US Customs will report you to your state of residence, and in a couple years, they'll send you a bill for the sales taxes you didn't pay, plus interest and penalties!  Wonderful thing, our Government. You can't buy the product in the state, but by golly they'll collect taxes from you if you go elsewhere to purchase them! And their 2 year delay assures them they'll get even more of your money.
Buying anything out of state or mail order/online does not relieve the buyer of the obligation to pay taxes on the purchase.  You are supposed to pay use tax if you did not pay sales tax at the time of purchase, but nobody ever does.
Storm-Tite quoted me about $100 per window more than Peninsula, so I think I'll stick with Peninsula if Hehr can't help me out.
Brian Elfert
gumpy
Quote from: belfert on May 30, 2006, 05:17:29 PM
I understand what the law says. I just believe it's unfair. Technically, you're supposed to report any item purchased out of state, and pay the difference of sales tax to your state of residence. Hogwash!
If I could have purchased my windows in the state, I'd have paid the sales tax. But I had to leave the state, and in this case, the country, to purchase a product I needed that was not available locally. Just because I live in a state shouldn't mean I have to pay the outrageous sales tax on a product you can't even purchase in that state.
That's why I do as much shopping online as I can.
Quote
There's a reason for the price difference. Not all windows are created equal.  Penninsula makes a good product, but it does not have the same insulation properties as the Storm-Tite window. However, for the way you intend to use your coach, Penninsula and Hehr will work well for you.
