BCM Forum
Incinerator Toilet
Started by dwbruner, May 23, 2006, 02:03:00 PM
dwbruner
I have been looking into an incinerator toilet made by Incinolet.  Their Model RV is made specifically for an RV and runs on 120vAC.  This would totally eliminate the need for a black tank and the mess associated with dumping, cleaning etc.  The toilet is not cheap (approx $1500), but I think the cost savings of no black tank & no plumbing to/from toilet, the space savings of no black tank plus not having to dump & maintain a black tank would offset the cost of the toilet in the long run.  They seem to be popular in the marine world.  Also good for basements and cabins where installing plumbing would be very expensive.  Here is their url...
http://www.incinolet.com/
Any feedback is appreciated.
Darrin Bruner
1985 Eagle Model 10
Dallas
Darrin,
I thought about the Incinolet, but since I can't afford one and have a regular RV setup already, I passed on it.
But, Hey, Travellers across our great land have been burning buffalo poop for centuries! ;D ;D ;D ;D ;D ;D
If it was good enough for grampa, it's good enough for me! ;) ;) ;) ;) ;)
Oh, give Me a Home.... Where the Buffalo Roam....  and the Beer and the Cantaloupe Playyyyyyyyy.[/b]
OneLapper
Hey there,
I worked with a guy a couple of years ago that installed one in a small camper.  For what it's worth, he loved it.  It solved the problem of a black water tank in a camper that he could not have one installed.  Of course, you'd be compelled to admit that you loved it after spending $1500 on one!
Mark
PD4106
OneLapper
1964 PD4106-2853
www.markdavia.com
pvcces
Be sure to run down odor and electricity consumption for these units; I have seen complaints about these issues in the past.
For what it's worth.
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Suncatcher
Ketchikan, Alaska
dpinson90
We have had the Incinolet for 3 years.....it is great......no mess....just empty the powder out of the pan about once a week.....no odor if proper installation is followed......makes camping out alot better!!!!!!      David Pinson...Eagle 05/10  1975
dwbruner
David,
How is your bus electrical system set up (genset, inverter, etc.) since the Incinolet requires power to burn the waste?  How many amps does the Incinolet pull during a cycle?  Can you operate it via the inverter or is it too much drain on the batteries?  I know with shore power & genset the electrical load will not be an issue, but curious if the draw on the batteries is significant?
Thanks for everyones responses!  :)
Darrin Bruner
1985 Eagle Model 10
darrenayres
Website says 1800 watts, 15 amps, 120 volts. Guess overall draw on batteries depends on how often you poop/pee.  ;) ;) :D
Darren
FloridaCliff
Even if this thing works perfect, No odor, easy cleanup.  $1500.00
100 gallon premade tank $300.00
Toilet $200.00
Misc fitiings and connections $100.00
You still need a gray tank so you have to go to a dump anyway!
Is it worth $900.00
And lets say your taking a leak and an electrical malfunction happens :o
Another Eunuch Bus driver ;D
At least it would be easy to keep your mind on the road. :P
Cliff
Mark Twain
