Lethal towed
Started by Jerry Liebler, September 25, 2007, 08:13:08 PM
Jerry Liebler
This was posted on the GM board.  Anybody know more?
Police report: Hummer came unhitched, headlined in the Sun News Daily
News (Myrtle Beach, SC).
A Conway man died in a car wreck Sunday when a Hummer came loose from
the bus that was towing it and slammed head-on into another car. The
wreck happened at 2PM on US 378 about 6 miles west of Conway, SC.
According to SC Highway Patrol a 1963 GMC bus was traveling West on
the highway pulling the Hummer. The Hummer came unhitched, it crossed
the centerline and crashed into the East bound 1995 GMC pick-up,
killing the driver who died of internal injuries at 2:30PM according
to the County Coroner. The driver of the GMC bus was uninjured. The
SC Highway Patrol is investigating the incident and will determine
whether to charge him.
Now is there any member of this board who could identify this GMC bus?
Have no idea what part of the hitch "came loose". With the various
posts I have followed on this board regarding fabrication of tow-
hitches the question must be asked, what failed? Seems safety
chains/cables could have prevented this event. Possibly an inadequate
hitch design, or fabrication might come to mind. What is the tow
weight of a Hummer? Comments please.
Songman
That's a shame.. on many levels.
It didn't really say what kind of Hummer. The gross weight of an H2 is 8600 pounds. The H1 is over 10,000! Even the little H3 is almost 6000. If someone plans to pull something that heavy they really need to make sure they have the right equipment and all in good shape.
Gary LaBombard
Jerry,
This is the reason I refused to pull a toad until I felt I was safely and adequately equipped to do so even if being pulled by a S&S.  I installed a brake buddy on my toad, it was pricey but after reading this post I am so relieved.  It was after last years rally at Arcadia that Christy & Larry posted about losing their toad when something come loose on the towing hitch and their toad just stopped safely when the break away did it's job. Even if the hitch was the failure or what ever the reason the Toad has to stop immediately when the (Brake Away Switch is activated) upon separation from bus.
I have noticed also that the use of the toad brake buddy really helps in slowing down both vehicles as the brakes are applied.  Now pulling a big Ole Hummer, I know I would have something there to assist.  FWIW from a Bus Nut Amateur.
This is a tragic lesson for us to learn but I firmly believe to be traveling with a brake away safety system, (Brake Buddy or such) that will activate the moment your toad separates from your bus would sure help in a tragedy such as this and also give peace of mind when you are in court as the defendant in a law suit because you did have one.  It almost seems obvious this Hummer did not have one if it continued to travel across the road after separation from the towing vehicle.
Yes, I have towed my toad behind my S&S and it wasn't a kid's wagon.
Gary
Gary
It surely sounds like a 4104 or 4106 bus...
This is a shame...
Most likely the hummer is a H2 or a H3 in the 6900lb range.
I think way too heavy for a 04 or 06 to be towing.
JackConrad
   If it was a '63 intercity GM bus it would be a 4106.   Certainly a tragedy for all involved.
   We installed an M&G brake unit on our Grand Cherokee. I made up the break away cable so this it will release just before the safety cables are tight in the event of a hitch failure.  I hope I never find out how well it works.
   I did test the break away braking effect on the Grand Cherokee by temporarily connecting the break away to a toggle switch. I aired up the break away air tank on the car, drove the car down the road in front of our house at about 45 MPH, put it in neutral, let loose of the steering wheel and flipped the switch.  The brakes applied and the car came to a stop in a straight line.  The stop was not a "tire slider" but faster than a normal "come to a stop".  Jack
zubzub
One thing I have always noticed about safety chains on trailler hitches is that they are attached to to hitch mounting.  this means that the only way they work is if the ball and hitch come undone.  If there is any other structural failure in the hitch, ie., the hitch mount detaches from the towing vehicle, safety chains provide no safety.   A break away brake is a great idea, also perhaps a safety chain from the hitch mount to the towing vehicle.  Just a thought.  Patrick.
JackConrad
Patrick,
  That is what we did. The break away cable connects to the bus frame. So as to not hijack this thread, see my new post "A few ramblings about brakes".  Jack
Charles Seaton
A 1963, could be a 4106 or any type of fishbowl.
Well,
This post pushed me to finally buy a brakeing system. I have been keeping an eye on prices and the new
models that just came out. For ease of use, and function, I just purchaced the new Brake Buddy Vantage..
I'll let you guy's know how it works for me. I have a N. Carolina trip in a week.
tomhamrick
Hey Nick, where to in NC?
Tom Hamrick
1991 Prevost H3-40 VIP
1981 Eagle 10
Forest City, NC
Quote from: tomhamrick on September 27, 2007, 05:03:36 AM
Hi Tom,
Moorehead N.C. to attend the Converted Coaches Chapter FMCA. I leave next Thursday Thru Monday.
It's a Seafood Festival weekend too
DavidInWilmNC
Although it's obviously a good idea to have the correct equipment in the event of a break-away, it's still going to take a long time to stop the toad.  Think how long it takes to stop any vehicle traveling at highway speeds.  There's still plenty of time for the toad to do a lot of damage (to other drivers), especially since there's nobody at the wheel steering it and no ABS.  As good as the brake-away systems are, I'd probably feel even safer knowing that I had mounted my safety chains or cables installed on sturdy brackets of some type.  I don't have a hitch yet, so any thoughts on the best place to locate attachment points for safety cables or chains on an MC-8 would be appreciated.
David
JackConrad
David,
   Our safety cable attachment points are on the hitch drawbar, but I am adding cables from that point to the bus frame. And I agree that it takes awahile to stop a toad. If the toad came loose and immediately went into the other lane, it would not be slowed very much when the impact occurred.  Jack
Stan
Safety chains are supposed to go from frame to frame and crossed under the towbar to prevent it hitting the road. Done properly, the tow will follow the bus in a straight line and with a little upgrade can be brought to a stop without the tow running into the bus. Yes, it happened to me with a broken towbar. I put the broken towbar in the trunk of the car and drove to the nearest welding shop to get a temporary repair and continued on my trip. Lost time about three hours and no damage to either vehicle.
Stan,
This is an interesting concept. I had not heard of this. If I understand correctly the chains would make an X from one side of toad to other side of bus frame, and likewise on the other side. I'm also trying to envision how it works when turning. If not please clarify. It sounds like a great way to secure in the event of tow bar failure.
