Change your background!!
Started by Nick Badame Refrig/ACC, April 03, 2006, 04:49:54 PM
I'm testing with a changed background,
So far It's Larger, and much clearer.
The colors are white and ocean blue.
I'll let you know if everything else works.
So far,
The smilies won't load while you are posting!
I'll try and post a pic.
Guys,
Go to Account, look and layout prefs., and there you can choose 2 differnt layouts!
So far still no smilies!!
plyonsMC9
Hey - the smileys are still available under the original theme - I just checked.  Not with the 2nd theme.  Wonder if they were just not a part of the older theme.  Anyone work with the old theme in the past and know the answer?  There are actually lots of themes that I could make available - the key point would be to find one which 1) provides smiles and 2) makes an easier-to-read background.
Hope this helps, Phil
Dallas
Quote from: Nick Badame Refrig. Co. on April 03, 2006, 04:52:41 PM
So far,
Nick, Where's that bus from? and who owns it?
If I ever get rid of my silver siding, I want a vinyl wrap like that! That's too cool!
Dallas
Dallas,
I found it on google, I have no idea where it's from.
But, Too KOOL, yes.
Dallas
Quote from: Nick Badame Refrig. Co. on April 03, 2006, 05:10:58 PM
Dallas,
But, Too KOOL, yes.
One more post Nick, and you won't be a newby anymore!
ALLRIGHT DALLAS,
You Just Tempted Me,
I'm trying not to post, I'm trying,
Oh No! I couldn't Resist, Oh Well heres 50
No more newbbie!
plyonsMC9
NEW THEME - just uploaded - called "SIMPLICITY"  All white!
Smileys work as well  - but - completely different look and feel.  YIKES!! Good Luck All!!!
Best Regards, Phil
YIKES,
The simplicity is weird!
I'm changing back to DEFAULT!
NJT5047
I was dinking around with the background and screwed something up.  Cannot get back to the original default screen  All the buttons and such are missing.  Is this a "test" of another format?
I'll try again.  The original format is similar to the ASTROSAFARI.com website and I was right comfy with it.   ??
JR Lynch , Charlotte, NC
Ayn Rand
NJT5047
Well. Now the "reply" links are visible.   I shall dink some more.  Reckon this prattle gets one off the "newbie" list.   I really would like to get back to the original screen if possible.   If it isn't somebody say so....quick!  Thanks, JR
Ayn Rand
plyonsMC9
Quote from: NJT5047 on April 03, 2006, 06:43:01 PM
Hi there JR,
Did you get it set back to "normal" ??
Let us know - Best Regards, Phil
NJT5047
Yep.  Got it.  This is a little more colorful you know...for us ADHD sorts.   :)
Ayn Rand
DrivingMissLazy
For those of you wishing to change your background, the following will (I think) allow you to select one of the three now available. You may have to look around some for the buttons as they are in different locations on each Theme.
Starting out from scratch, open the board and find the home button. Click on it. Nothing really should happen.
Then find profile and click on it.
Then click on modify profile
Then find and click on Look and Layout Preferences
Edit profile screen should then come up and show your current Theme.
Click on Change.
Then select the theme you want to try.
Then click on use this theme.
That should be it. You should then go back to home and be in the new theme.
WOW. Would you believe I typed all this without a typing error. Sure is nice to have the Google spell check to verify this though. LOL
