In-Motion satellite: KVH TracVision R5 / R6 vs Wineguard & others...
Started by DROdio, May 17, 2006, 06:07:55 PM
DROdio
I'm having the darndest time figuring out what the difference between the KVH TracVision R5 & R6 is.  Can anyone shine a light on this?
Also, any recommendations regarding the best in-motion satellite for the money?
Ideally I'd like to buy my own receiver (i.e., for DirecTV or Dish service) and just buy the satellite.  Will this approach work?
Has anyone tried just having 1 satellite subscription between their home & bus, and then switching between the two?  Isn't there some sort of card you can swap between the receivers in order to be able to do this?  Doesn't make sense to pay for a service that we wouldn't really be using much...
"WonderlandBus"
1989 VanHool T-815
Daniel@WonderlandBus.com
www.WonderlandBus.com
Hi Danial,
The A5 is only 5 1/2" tall and uses new tech called [ Phased Array ]  think of a funnel cloud, that shape is how they pick up the signel
instead of a dish having to look straight at the satelite. It has always been a problem for me with my L3 when I 'm driving past tall trees.
The picture will freeze until the trees pass. I've tested the A5 in a friend's escalade, only the usual dead spots, tunnels, parking garages,
super tall buildings.
The 6 is KVH's newest RV model, claims to be 3" shorter than the L3 with a different kind of dish inside. I havn't tested it yet! Big Bucks Though!
I have 6 recivers on my direct tv account, 5 house, 1 bus. I wish I baught the 12v reciver for the bus because when I switch from shore power to
inverter, that 100th of a second is enough for the reciever to flash and send the dish into search. A 12 v unit won't do that! The only problem with
traveling with your reciever is that you loose your local stations but, you can call Direct tv with the zip code your in, and Wala, you got local stations.
As soon as I sell my L3, I'm getting the A5, mostly because of the Low Profile. You saw my 14" hat on my roof, dosn't look good with my smooth top!
http://www.kvh.com/pdf/TVA5comboWEB.pdf
ChuckMC8
I have a Datron DBS-4000, it is 12V, so no loss of signal on power-ups. The Datron line was purchaced by another of the satellite mfgs (KVH, I think) and the line discontinued.
   It works great, with Direct TV. I pay an extra $5 per month for the extra receiver. I listen to XM radio thru it every day while working on the bus, so its a great deal at $5, not having to listen to commercial radio.
  It does occasionally lose signal on streets with tall trees close to the road, but is seamless on xpressway and clear roads.
It is so nice to have all the avail TV channels for the family while traveling.
Danny
Regarding sharing the satalite receiver between the house and bus:  I talked to the Direct TV folks and they said it was not a problem.  You could just take the receiver out of the house and place it in the bus when traveling.  The card would continue to recognize the receiver and yours.
I have not done this yet - not there in the process.  However, I am going to try this when the day comes.
Danny
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
Danny,
I did that for a while, Than I got lazy!
I just keep 1 in the bus now mostly cause the wires, repowering the unit up, and fitting it back into the built in cabinet!
Chuck Newman
Nick & Chuck,
Between Winegard, KingDome, and KVH, have you talked to users about rain fade.
I want the fixed position antenna unit in a dome, and I know not all respond the same to
rain fade.
Any feedback from other users of each?
Chuck, several years ago I ran a DSS receiver from a very small about $30.00 inverter in
a previous coach.  Did so because 120vac was not available over the windshield.  It
powered the receiver with no problems.  That said, I like to run everything possible
on DC.  Is anyone currently making an AC/DC DSS receiver?
Thanks.
1989 MCI 102A3, Series 50, DDEC III, Allison 740D
ChuckMC8
Chuck N.- I had to use a specific receiver with the datron satellite controller. There were several brands/models to choose from.
My unit came with a Sony receiver that has a RF remote control. Very cool, because I can change the channel from the bedroom with the door closed or outside , when sitting under the awning watching the big TV in the bay.
    I'd bet finding a DC receiver would be a good possibility. First, look to the alternative power folks, such as
http://www.backwoodssolar.com/  call them and someone there will know for sure-
hope this helps, Chuck L.
ceieio
Quoteinverter, that 100th of a second is enough for the reciever to flash and send the dish into search. A 12 v unit won't do that! The only problem with
Nick - you may be able to get around that, with a little fuss.  The manual for my KVH suggests that you turn off the 12v power to the dome when you are parked (after acquisition) as the dish no longer needs power once locked on.  Their reasoning was as a power saver.  If you parked while the dish was locked on, you could just power the dome off on your way out the door to tend cords etc.
When you turn the dome power back on, it will do POST (power on self test) and seek the satellite again, so you will and the nuisance of that delay to require the satellite that you were already pointed at.  If you put that step in the right place of your departure checklist, it should be of little impact.
Craig - MC7 Oregon
Craig MC7 - Oregon USA
Hi Craig,
I know what you mean, Thanks.
Yhe complaint I have is the reciever aqusition, it takes about 4 min to recieve picture.
Gary W
  Speaking of satellite systems,  I have a Datron DBS-4000 that quit working, II think it is a software issue. I talked to techs at Audio Vox that bought out Datron. They said there are not very many dealers that repair Datrons. There is one in Apache Jct AZ. Does anyone know of a place to check out Datrons in the north west Oregon or Washington.
Gary
ChuckMC8
Gary, I have the service/installation manual for the Datron DBS-4000. if I can share that info with you, just drop me a note.I can scan and email if needed- Chuck Lott
stephenstay
Chuck, I'm trying to get my datron 4000 up and running too so I'd like to take you up on your offer for manuals.  I've PM'd you.
Gary, I've found a source for two rebuilt datron 4000 antenna control boxes.  PM me if you want details.
Cheers,
ST
FloridaCliff
Just a little trivia on the A5 antenna technology.
The technology for phased array is actually from the 50's-60's.
I worked on the BMEWS (Ballistic Missle Early Warning Site) site in Greenland and they were using the phased array radar up there.
I guess someone found a good use/market for it on the receive end because of DBS.   Interesting.
Cliff
Mark Twain
prevosman
After struggling with trouble shooting, talking to techs, buying parts that did not cure the problems etc. I found if you want the most reliable the one entertainers use (they can't get repairs on the road when working to a schedule) is the TracStar.
After having it since February I can tell you it is trouble free and it locks on to a signal faster than anything else we ever had and when in motion it stays locked on like a junk yard dog.
But there are no bargains.
Jon Wehrenberg
Knoxville TN
1997 Prevost Liberty
