Electrical hookups for captain chairs
Started by Danny, June 22, 2007, 10:55:24 AM
Danny
 I bought two captain chairs to install.  They are Mountain Aire and have electric everything including heat seats.  My questions is what size breakers (fuses) would I need to such a hookup.  I assume they are DC.  I can't see the motor or don't have any spec information.
Any ideas?
Danny
I have heard it said, "life comes at you fast".  I didn't know it would be in the shape of a bus  :-)
Eagle
They are DC and a 15AMP fuse one for each chair will work.
Brian Diehl
15amp fuses may be underated.  I have FlexSteel chairs and they will put my 10amp DC converter (peak output of 12amps) into over current shutdown when the motors hit their stops at the end of travel.  I bet they peak over 20amps.  Maybe use slow blow fuses or self-reseting circuit breakers.
DrivingMissLazy
I would suggest you fuse the seat heat circuit separately from the positioning motors.
JackConrad
Don't forget to match the wire size to the fuse size.  Larger fuse needs larger wire.  Jack
