MC-9 Roof a/c
MC-9 Roof a/c
Started by cpschevy, May 05, 2007, 10:24:02 PM
cpschevy
I am looking at the carrier low profile ducted units (so my bus will fit out of my shop door when im done!)any ideas on sizing and how many i need?I see everyone putting at least 3 13,500 btu units on but most people i talk to say they never use more than 2 at a time! Do i really need 3 or can 2 keep up? any input or recomendations would be great!        Thanks Chris
Hi Chris,
Welcome!
First, tell us what bus you have, is it a saudi? and how well you insulated it. Then it will come down to, how cool do you like it inside, what climate do you live in? etc.
Theese factors are what you should concider before making your decision.
Good Luck
oldmansax
We have 2 on our MC7 & find they will not do the job when it is very hot or when driving into the sun; however, I found out the PO did not change the original insulation when the conversion was done so more insulation would help.
TOM
1995 Wanderlodge WB40 current
1985 Wanderlodge PT36
1990 Holiday Rambler
1982 Wanderlodge PT40
1972 MCI MC7
JackConrad
As Nick and JJRbus mentioned there are several variables that have to be considered. What is YOUR comfort range? We live in South Florida and keep our ACs (both home and bus) set at 80 degrees. Where will you be using your bus? Big difference maninting your comfort zone in Florida or Michigan.  How well is your bus insulated? We have 2" spray foam in walls and about 5" in ceiling. How many windows and are they single or dual pane? Do you have awnings over your windows? What color is your bus? We did a test a few years ago using a laser temperature gun. In the middle of the afternoon in July, west side of 2 buses. Our white bus was 113 degrees. A friends dark metallic green bus was 140 degrees. All that extra heat that is absorbed has to be removed by the AC system.  We keep our bus comfortable with 1 RVP (formerly Coleman) basement unit that is rated for 24,500 BTU. This unit was installed using ducts sized per the manufacturers recommendations.  Jack
NJT5047
My MC9 has two Dometic heat pumps that do a good job of cooling (and heating) the bus.  Like Jack says, what's comfy for me may not be for another.   I've also got foam ceiling and walls.  Makes big difference.
The Dometics are low profile...about 9"?  They are low.
Anyway, I've got the same problem with building clearance.  If you are close, and that must be the situation, this is a good time to add leveling capacity to your bus.  Then the choice of ACs won't be limited to low profile units...although, the low profile units look better than the tall ACS.
Create a way to dump the air from  the drive and steering axle (while keeping the air system up) and the bus will lose from 5 to 7 inches.  I would recommend moving only enough to get the bus into the building when the airbags are flat.  I poured a concrete pad for that purpose.  No jarring.
Best, JR
JR Lynch , Charlotte, NC
Ayn Rand
I have 3-13,500 roof tops that are spaced- front, near enough to the drivers seat that I can feel it. Middle of the bus and rear right over the rear bed.  Mostly use the two front and kick on the rear when over 100 degrees (which when it happens, am very glad it is there!).  Plus you then have a built in redundancy if one gives out-although in 12 years hasn't had anything go wrong with them.  If I were to do it again, would most likely use the 15,000btu Dometic Penquin, with two in the middle and front position.  Rear always seems to cool easily once the engine heat is gone.  Good LUck, TomC
NewbeeMC9
I like the recovery of the condensate evaporation on the carrier.
I bought my bus with 2 Colmans already installed.  They are also in the Emergency Hatches.  I recommend keeping the hatches also if possible.  you'll miss them if they're gone.  also offset to the side might buy you a couple inches.
GET SLOW SPEED FAN!!!!!!!
I have white paint on mine for cooling purposes.
if you have the floor up there is a lot of room under there for duct if you want to run a basement air
let us know what you come up with 8)
cpschevy
will to everybody, thanks for your input !   what I have is a 1983 mc-9 rite now it is in the wall framing stage and i am putting 1  3/4 inches of polycynurate sheet insulation by Dow in the walls.that should give me 11.5 r-value according to the tech at dow. than i am putting 4 inches in the ceiling which = around 22 r-value the floor will probably be the same.the color is going to be white with grafics on the sides.I live in Idaho and the bus will be for camping and also road trips to different states . temps around here are around 100 degrees in the valley where i live and 80 to 90 in the mountains where we camp.the windows are all thermo pane except the winshields of coarse and there are  windows. when i first decided to build a bus i wanted a basement air but a friend of mine that sells motorhomes told me that everybody was complaining that on 100 degree days or when parked on asphalt they would not keep up. and when we borrowed our friends 36 foot winabago it did that  exact thing. itwould only get down to 85 on a 100 degree day! I like a comfortable 75 to 78 degrees when we are travelling.
        thanks everybody      Chris
NewbeeMC9
I also have some of this mixed into the roof paint.
http://www.hytechsales.com/insulating_paint_additives.html
hard to say but i think it helps.
my bus stock insulation and single panes , it only get into the 90's inside when sitting in the sun closed up.
jdr
Chris, Give me a call MCI 9 Caldwell 870 4342
Kwajdiver
My MCI-9 has two roof airs.  Currently in Phoenix, temp hit 100 today.   Three days ago the bedroom A/C stop cooling.   :'(
Can't get in to a shop till Wednesday :'(  :'(
Wish I had three overheads..... ???
Bill
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
NJT5047
Bill, go to the local discount RV store and buy another AC.   May be cheaper than paying to have your old unit repaired.  All you need  is a farm tractor with a loader (campground probably has several).  Set the AC unit right in place.  Easy to replace.
You ruled out 110V and 12V (if necessary) problems?
Use the old unit as a spare...if it's repairable.
Good luck, JR
Ayn Rand
The two 13.5s in my 4104 won't keep it cool in very hot sunny conditions, so sun and it is very comfortable.
Fortunately for us the PO installed two folding doors, one separates the bedroom and the other separates the kitchen area from the front. We close both these doors, crack open some windows in the closed areas and the one AC in the front keeps it comfortable, not really cool, but comfortable. I also cut a hole in the front housing so the air blows straight down, no turns to slow it down. This really helps. I've never had to turn it to HI COOL since cutting the hole.
JackConrad
    Worst case scenario, if no tractor or machine to lift the AC to the roof, I have installed several Roof ACs by placing an extension ladder against the side of the bus, placing the AC (still boxed in the shipping crate) against the ladder. Put a strap tightly around the AC  box, attach a rope and from the roof of the bus, pull the AC up the ladder onto the roof. The old AC is then placed in the box and lowered the same way.
    Of course, IF you have a tractor available it is much easier.  Jack
NJT5047
Jack mentions something that is important...the sealing gasket is typically attached to the AC unit.  Never slide an AC around on the gasket.  Once out of the box, it must be picked up and placed in location.  Once on the roof, one person should be able to handle an AC.  You will need a helper inside to locate the retaining bolts.
JR
Ayn Rand
