DON'T LET A $20 CONNECTION PUT YOUR RV AT RISK. Get SmartPlug instead
Started by Gary Hatt - Publisher BCM, July 20, 2026, 01:55:25 PM
Upgrade Your Shore Power. Upgrade Your Peace of Mind.
Every time you plug your RV into campground power, you're trusting that connection with everything you own.
Traditional twist-lock plugs can loosen over time, leading to heat, corrosion, and the risk of dangerous electrical failures. SmartPlug was engineered to solve those problems with a safer, stronger, and more reliable shore power connection. Its straight-in, locking design provides substantially more electrical contact area than traditional twist-lock connectors while helping reduce overheating and corrosion.
Why RV Owners Choose SmartPlug
•   ✔ Safer shore power connection
•   ✔ No more twisting or fighting the plug
•   ✔ Positive locking system keeps the cord secure
•   ✔ Weather-resistant design helps keep moisture out
•   ✔ Heavy-duty marine-grade construction
•   ✔ Available in 30-amp and 50-amp RV systems
•   ✔ Simple retrofit for many existing RV and bus power inlets
Whether you're parked for one night or living on the road full-time, SmartPlug helps protect your coach—and everything inside it.
Power Up With Confidence.
Learn more at:
https://smartplug.com/
Safer by Design. Built for RVs. Trusted by Travelers.
1999 Prevost H3-45
