front spindle on drivelr side on 1980mci5c bus
Started by ridgeroadrunner, March 28, 2026, 06:58:38 AM
ridgeroadrunner
need help in finding front spindle diver side or a place to get it refinish on a 1980 mci5c bus  i live in central mo.
1980 MCI 5
ridgeroadrunner
 front spindle on  driver side on 1980mci5c bus need a place  to work on it and a place to buy the parts. I live in central Missouri
1980 MCI 5
Dave5Cs
Check the parts number I recall the front axle on the 5C to be the same as the MCI 9,I am not positive but if so they should plentiful used, both used the same size tire,  brake drums, hubs, seals, bearings and other components  from the factory ,they are not bus only trucks used the same with that front axle,the knuckle is expensive new over 600 bucks
