Tame the Heat in Your RV Conversion — For Good
Started by Gary Hatt - Publisher BCM, March 02, 2026, 08:38:32 AM
When you're building a home on wheels, controlling heat isn't optional; it's essential. Engine bays, firewalls, floors, and rear bedrooms can turn into ovens without the right protection. That's where EHP Rollboard Insulation from Engine Heat Protection makes the difference.
Built with advanced high-temperature ceramic material, EHP Rollboard is rated up to 2300°F, giving bus, truck, or van converters serious protection where it matters most.
Perfect For:
•   Rear engine compartments in motorcoaches
•   Doghouse and firewall insulation in buses, trucks, and vans
•   Bedroom floors over engine bays
•   Generator compartments
•   Exhaust-adjacent areas
Unlike traditional foam or fiberglass, EHP Rollboard doesn't soak up heat and slowly release it back into your living space. It blocks extreme radiant heat at the source, helping keep your conversion cooler, quieter, and more comfortable.
✔ Thin profile — won't steal precious interior space
✔ Flexible and easy to cut for custom installs
✔ Flame-retardant and built for extreme environments
✔ Ideal for serious DIY builders and professional converters
If you're investing time and money into your bus or van build, don't let heat be the weak link.
Upgrade your build with EHP Rollboard insulation and feel the difference every mile.
Visit www.EngineHeatProtection.com  to learn more.
1999 Prevost H3-45
