MC9 luggage door spring supplier
Started by Seann, August 29, 2025, 11:38:39 AM
Seann
Just pulled broken one out...where can I get a replacement? Any chance Canada somewhere? Need 3 rollers and a spring assy,
Seann
1984 MC9
Seann
Here's what came out...hopefully no one was under this when it let go!
1984 MC9
Retrofit  with a set of Prevost luggage bay gas shocks, they are fairly inexspensive along wit the mounting hardware.
Van I don't know if you could make the Prevost door setup work on a MCI or not ,they have a inner door that is part of the hinge and they hinge from the bottom,I looked at on my MCI to do away the cables and spring ,you know me I looked at for a week and decide naw to much work involved I never liked the setup MCI used
Seann
So, did you just stick with the spring setup? Anyone know the MCI part number for a replacement?
1984 MC9
Dave5Cs
See how the Prevost door is made and hinges
Dave5Cs
Home Depot cables etc. No one makes those anymore unless Luke in Vineland NJ has any.
A wire rope supplier should be able to make the 2 cables for you 1 end has a ball stop cripped on it for the yoke to slide on the cable,you may find something at H/D to work for you but the OEM was 1/8th inch aircraft cable real flexible stuff
lovetofix
Quote from: Dave5Cs on September 01, 2025, 06:36:44 AM
He still had some of the kits a year ago.
Seann
Did think about just replacing the broken cable...is there a trick to getting the "nut" out of the spring?
1984 MC9
