Cummins M11 oil pressure issue
Started by lhwood, June 27, 2025, 08:17:03 AM
lhwood
Looking for ideas here.  I have a '99 M-11 Celect Plus that has an erratic oil pressure issue at 1500 and higher RPM's. It makes normal pressure and then the needle dips and dances if held at a steady rpm.  This is observed on the CELECT as well as a mechanical gauge.  I've changed the pressure regulation spring and verified that the related system is correct per Cummins specs.
Thanks in advance.
Durwin
Durwin
1992 102-C3, 8V92 DDEC II, HT741 5.0mpg
Now swapped to a Cummins M11 450 w/Allison 4060 7.2mpg!
