Building Your Own Custom Holding Tanks
Started by Gary Hatt - Publisher BCM, April 16, 2025, 07:30:43 PM
This article provides a detailed, cost-saving method for constructing a custom holding tank using plywood and fiberglass. It begins with planning the tank's size and shape, calculating its volume, and sketching out locations for fittings like drain holes and sight glasses. The tank is built from ¾" plywood, assembled with glue and screws, and reinforced with corner braces.
Fittings are custom-made using PVC pipes and sealed with high-quality caulk. Once assembled, the interior and exterior of the tank are coated with fiberglass cloth and resin to ensure durability and waterproofing. After curing, the tank is tested for leaks by filling it with water. The top is then sealed with caulking and screws.
To prevent freezing in cold climates, the article suggests placing the tank on a waterbed heater. Lastly, installation into a bus or RV can be done using brackets to secure the tank.
Click on the link below to read this archived article.
https://www.busconversionmagazine.com/articles/conversion-and-nomad-life-tips-tricks-and-information/building-your-own-custom-holding-tanks/
Become a member of BCM for only $12 annually and gain immediate access to all New Articles and Buses for Sale six months before non-members. You will also have access to other valuable information and discounts on all RV components, as well as the ability to read over 2,500 articles on Bus Conversions that apply to any RV conversion you are interested in.  To access all this information, select the "Become a Member" option at the top of our website.
1999 Prevost H3-45
