BCM Forum
Rockwell Differential ID
Started by Sebulba, October 11, 2024, 08:28:48 PM
Sebulba
Hello all,
I have a possibility of needing to replace my differential.
I am wanting to price some rebuilds, but sure of the type of differential.
I called MCI and gave them the last 5 of VIN.  They say I have a Rockwell Carrier Differential with 4.56 ratio, and also gave me the serial number.  No model number though :-\
Is this all of the info I need to find the right one?  Also, if you have a suggestion of where to look, I could use that too.
Seb
Fowers are parting out a lot D's 1-800-872-5475 they will probably sell you a center,they are asking $2000.00 for the complete axle with brakes, don't get confused if they say we don't have any Rockwell only Meritor they are same
bronson
I have a complete rear axle from a 84 mci 9 . No idea if it would fit. I'm in ohio
Gary Bronson
1984-MCI-9
Mount Orab Ohio
Sebulba
Ok, that's all fine.  My issues at present is that I would like to know the model of the differential.
Yes, If I could get under it right now I could look at the tag, but I can't, so I was hoping someone might know what model of Rockwell it is.
Seb
Quote from: Sebulba on October 16, 2024, 11:03:02 AM
Seb
I don't have my D series manual anylonger but  call JD Bus repair or Luke I  think they all the same model for the D and DL with just different gear ratios my manual showed 3 different gear ratios for the same model,the number from the manual won't help they use MCI screwed up parts number ,I just called for the number
Sebulba
Quote from: luvrbus on October 16, 2024, 01:56:58 PM
Hello Luvrbus,
Thanks, MCI could tell me the gear ratio and the Serial #, but not the model number.  Want to price rebuilds and decide where I'm getting one before I rear into it.
Will check with Luke.  Don't know JD Bus repair, but will look around.
Thanks again
Seb
LOL I screwed up talk to JD at C&J  1-800-228-7349 none better on a  MCI
Also check with Sam @ Caylor Supply (785) 878-3405
Sam's been partying out MCI's for years!
Sebulba
Well, just to finalize this thread, before we left the farm, we jacked the rear wheels off the ground and stuck a scope in the filler hole.
Then we turned a drive wheel very slowly while looking at the ring gear with the scope.  Didn't see any teeth missing and while turning the wheel, felt nothing less than complete smoothness.
Did this in both directions and with 1 wheel chocked and without, so tried to see and feel everything we could.
All seems good, so we are hoping for the best and going with it.  Maybe those pieces that ce out when I changed the oil were from a previous third member and we're just not cleaned out when a new one was installed.
Still a bit of a mystery, but at least we looked at it and didn't see anything.
Sen
Sen, did you check the pinion gear? Or the pinion bearings? I've seen more pinion failures that ring gear failures.
:D BK  :D
Sebulba
Quote from: Busted Knuckle on February 10, 2025, 04:16:40 PM
:D BK  :D
We didn't.  They are covered with oil.  The pieces that came out, we think looked more like ring gear pieces.
As I turned the wheel while looking at the gear, it felt smooth and heard no growling.
We hope it's ok
Thanks for the input.
Seb
