Engine Coolant Circuit
Started by Craig R, May 14, 2024, 08:14:26 PM
Craig R
Can anybody tell me where the coolant is diverted from when it is sent through the heater core in an MC5c?
Can someone describe that entire coolant-flow circuit?
* Path from the engine through the left radiator - and back.
* Path from the engine through the right radiator - and back.
* Point of diversion to the heater core - and point of return.
* Location of each thermostat in the whole scheme of coolant flow.
The path on the 2 stroke goes through oil cooler 1st ,into the engine, both sides of the engine are tied together at the rear into the heater core for feed with a return line tied in on the lower block water passage and out both thermostats to the radiators , it is in section 5 of your manual
Craig R
Engine (6V71) manual? Bus (MC5c) manual?
Perhaps I should try to buy one of these manuals!
windtrader
fyi - check out bus grease monkey website. you might find some docs you need there or check around here, Gary may have info too.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Gary Hatt - Publisher BCM
Quote from: Craig R on May 15, 2024, 05:58:14 PM
Yes we have the MC-5 manual.  We can ship it out within 24 hours. Members get a 10% discount on all manuals.
https://www.busconversionmagazine.com/product-category/bus-manuals/
1999 Prevost H3-45
