LED Dash lights for 102D3
Started by jozef, December 19, 2023, 02:56:16 PM
jozef
Are LED replacement bulbs available for the dash lights for later model MCI busses?
Jozef
MCI 1997 102D3 converted
MCI 1975 MC5B converted
Lethbridge, AB
Utahclaimjumper
Just remove one of the originals and go online to see what the replacement LED is..>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
freds
Quote from: Utahclaimjumper on December 19, 2023, 05:11:17 PM
Will they respond to dimming? Don't LED's have to be electronically dimmed?
My CC had 12v LED's  dash lights that used  dimmable driver to dim the lights ,LED's drive you nuts on the dash without a constant power driver and dimmer mine quit and I hooked it up direct for a month till I got the new driver
windtrader
Quote from: freds on December 19, 2023, 07:03:01 PM
Yes, they run a3 3.3-5v and will operate directly connected to DC source. If you want dimming you do not do that by lowering voltage like analog bulbs. They are dimmed using PWM that basically flashes them at a frequency to vary lumen output.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
