EHP Ceramic Insulation
Started by sandra@BCM, November 15, 2023, 01:06:49 PM
sandra@BCM
E.H.P. (Engine Heat Protection) is a ceramic material designed for insulation purposes. It is widely used to protect components from heat sources such as engine pipes, mufflers, cooling systems, generator compartments, and more.
E.H.P. comes in various configurations to meet your needs structurally, cosmetically, and physically and is ideal for use as a high-temperature heat barrier. In addition, many of the E.H.P. materials can also function as noise barriers.
Its heat insulation features are comparable to acoustic insulation qualities, which help to minimize noise intrusion. E.H.P. materials can be used in almost any application where heat and noise reduction are important, including Street Rods, Antique Automobiles, Airplanes, Boats, RVs, Trucks, Buses, Motorhomes, Commercial Buildings, Industry, and even in the Home.
To read more about EHP and its products, click below:
https://www.busconversionmagazine.com/bcm-blogs/ehp-ceramic-insulation/
#BusConversionMagazine  :)
#buslivin :)
