Surge protector
Surge protector
Started by chessie4905, August 04, 2023, 07:52:09 AM
Anyone familiar with these?
windtrader
looks like a real old plug adapter, long before they made the molded ones.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
No, plug and socket 50 amp. Electronics inside.
TNBrett
post a pic of the inside.  It's probably something like a voltage sensing relay.  It senses the voltage coming in and only closes the contacts if the voltage is say between 215-250v.  That would be fairly easy to do inside an enclosure like that with off the shelf parts.
1964 MC5 that's a work in progress.
dtcerrato
Quote from: chessie4905 on August 09, 2023, 02:44:56 PM
Pictures of inside.
I see a heavy contactor and a printed circuit board. The circuit board probably keeps the contactor in the normally closed position when things are normal and rapidly opens the contactor when voltage outside of it's set perimeters are present. That's my guess.
Dan & Sandy
North Central Florida
PD4104-129 since 1979
windtrader
I agree with Dan. There are contacts so I will assume one end of the wire to the box goes to one side and the other wire goes to the other side of the contactor. I can't determine if it is NO or NC but that board does detect some electrical level or condition and either opens or closes the contact.
It could montior low voltage and prevents power from passing until it is in range. It could monitor high voltage and cutoff power if too much comes in, spikes too? If there is capacitors then that could indicate some form of surge protection.
In any event, it is generations old and something like that is dime a dozen, once you figure out what it does. lol
Don F
Fully converted
Bought 2017
The generator to shore power change overs with surge protectors look about the same inside as that
Did some research. Company sold surge protectors a while back. No longer in business. Thought one of the geezers here may have had one.
