For Sale MCI/TMC MC-9 RV Conversion.
Started by BlueScarecrow, June 25, 2022, 09:51:35 AM
BlueScarecrow
1983 MCI/TMC MC-9 RV Conversion, DD 8V71 300+ HP Pusher, 5 Speed transmission, .New Fuel Pump, New Maker Lights, New Batteries, Buildout includes uniform studs and new insulation, factory windows removed and replaced  with leak-free aluminum panels New toilet and sink in box. HD Custom Towing Package with 5 Pin Flat Connector and magnetic light bar. Custom suction valve installed to draw fuel to fuel pump when run dry. Pressurizing the fuel tank doesn't work, but the valve allows one to draw up fuel through he strainer and filter instantly.; then the engine will start on first try. Most of the air leaks are fixed; and the bus airs-up just fine.The air operated cooling fan tensioner was removed and a constant tension hardware device installed. Run-away flapper valve - refurbished. Smokes on startup as all 2-strokes do, but clears soon. Goes down the freeway like a scared rabbit.
Contact Mike  (602) 618-5327
1983 MCI / TMC MC-9 Crusader II - DD 8V71  Located in Scottsdale, AZ  85252
Do you think that's air you're breathing? - "The Matrix"
