Broken Teleflex odometer
Started by Iceni John, January 01, 2022, 10:32:54 AM
Iceni John
Does anyone here know how to fix the odometer in a Teleflex electronic speedometer that no longer records distance?   The speedo function still works correctly.   I assume (but I may be wrong) that the odometer has its own motor to drive it, deriving its signal from the front wheel's pickup sensor.   I've searched the web, but found no info on this problem.
Thanks, John
2kW of tiltable solar.
Coach_and_Crown_Guy
John, you know as well as I do that stuff isn't meant to be repaired today. I'd call Zacher and see if he's got some on the self he can sell you. May even have Teleflex too. It's no big deal to just put in another brand as long as the input pulse stuff is matched OK. Most will allow for a range of input pulse counts to match different sensors and locations. Call me if you need the number. Happy New Year!
