Fan drive
Started by olebusman, November 06, 2021, 07:59:30 AM
Didn't the OEM fan have a flange on the fan that fits inside the drive to center it up with 6 bolts for the direct drive and the torus used a outside flange for the fan center ?
Measured the lip diameter that centers fan blade. 3.675" provides a nice fit with hole in fan.
olebusman
RJ. Give me a call please. I'd like to talk to you about the torus drive. 352 five  eight  five 77 six two.
uncle ned
olebusman
Sorry for being so slow about getting you pictures.
Hope you can get some idea of how Huggy has her fan driven.
Took a lot of experimenting and plenty of money and time to get right.
good luck with your work.
uncle ned
4104's forever
6v92 v730
Huggy Bear
you can actually put a torus drive on the 4104 6-71. We did that years ago. Took it off an old look city bus. didn't use that long extension like 8v-71.
olebusman
RJ did you forget me? I haven't heard back from Luke either. Sure want to get a torus assy to end this problem
olebusman
Well, I guess nobody on the board has a torus assy. Anybody have any suggestions on where to look
did you get in touch with Luke?
olebusman
chessie4905, I've talked to Luke 3 times with no call back. I must have made him mad about something. Van, I sent a message to Tal Cook  House of rust. Still waiting for a reply.
olebusman
Van. I called Goodsons which sent me to Cardinal coach which sent me to Bell Town Recycling. So far no luck. Still waiting for a reply from Tal Cook
6805eagleguy
Lol tal cook is quite the fellow. Somehow he's mad at me right now, cause I was pricing out radiators, and didn't want his. And now he's mad at me
1968 Eagle model 05
since you have the 6v92, the torus will probably be run in full lock up all the time. lockup is not the correct term, but with higher output engines, most have bypassed the Vernatherm and plumbed the oil lines together. Maybe you could post a few pictures of what your current setup looks like. Is the main casting off the block including the oil filter also like 8v71's?
Been thinking about your dilemma some more. Since you are in Florida, I would see if you can remove all the rubber cushion, clean those surfaces by sand or glass media blasting, and contacting one or more urethane molding companies in Florida and see if one can inject molten urethane into the former cavity. Trim it up and should work fine. The critical part would be getting the inner part exactly centered. Or maybe see if one of them would be interested before you remove the rubber part.
The guys on the 4106 FB  page should have one ? have you asked there
