Fan drive
Started by olebusman, November 06, 2021, 07:59:30 AM
Dave5Cs
Quote from: RJ on November 06, 2021, 01:47:39 PM
FYI, Luke doesn't work weekends, only M-F 9:30 - 4:00 Eastern. 1-888-262-2434.
FWIW & HTH . . . ;)
Nope Mon through Thursday no longer works Fridays
richard5933
Quote from: Dave5Cs on November 07, 2021, 08:25:55 AM
Asked him about this specifically just a few weeks ago. He is working on Fridays because he's too busy to take the day off anymore.
olebusman
Bill, that would be ok but half the rubber is gone. Chunks come out when we took it apart .
Bill Gerrie
I've never seen the drive. Any way to jamb the rubber back temporarily. Wish I could help you.
sledhead
to get you home how about drilling a hole in it and putting in a nut and bolt like Bill said but also injecting a good rtv silicone to fill the space then letting it dry ? so long as it does not vibrate it self to death ?
dave
dave , karen
here are pictures of mine. rubber insert is right at end of blade and a cross pin to hold it incase cushion fails. Maybe yours is off an RTS which could be different.
olebusman
 Chessie, I was hoping but that is not the same. I'm afraid to cobble to much. It could take out the fan drive and/or the oil pump housing. Possibly the crank. I don't think I'm brave enough to chance it. Someone somewhere has one. I've just got to find it. Still broke down and still hoping. Is Gene Russell a possibility.  I'll call Luke again tomorrow. Maybe he has come up with something.
Quote from: olebusman on November 07, 2021, 05:21:48 PM
If all else fails find a used torus drive cheap they bolt up the same only thing you would add is a oil supply line and let it run full speed that coupling is a tough find from 40 years ago
Quote from: richard5933 on November 07, 2021, 08:48:22 AM
Luke told me he was working 4 days a week to be with his wife before she passed away and is now back to 5 days a week
Quote from: olebusman on November 07, 2021, 09:12:53 AM
There should be a outfit in Nashville that can repair that ,when I worked for Tennessee Gas there was a couple of places that did vulcanizing on our compressor coupling CRS but I believe it was Nashville Rubber and Gasket
Also check an RTS site. That whole engine and trans probably similar fan drive setup
Try this one in the morning. Maybe they can help.
https://busfixx.tripod.com/busservice/id13.html
Quote from: chessie4905 on November 07, 2021, 06:34:25 PM
John the owner of that business died several years ago all his parts are setting in a old school house in Kansas and the wife has shut it down.A couple of us are trying to buy his inventory
olebusman
Does anybody have a phone number for Gene Russell. The number on the website is no good anymore.
in case you have no luck. I can give you dimension from end of fan attachment to block.
measured mine. end of fan hub the blades are attached to absolute surface of cylinder block is 21" leading edge of blades, 1/2" back from end of hub.
