factory wiring
factory wiring
Started by 82 MCI-9, March 13, 2007, 08:02:05 AM
82 MCI-9
When i raised the roof i had to cut some of the wiring that went to the marker lights and other stuff that i am just moving to different places. My question is  is this just automotive wire or is it a different grade of wire? It looks like automotive wire just want to be sure Thanks Robert
JackConrad
Yes, automotive wire os Ok for 12 volt and 24 volt wiring. I would not use it for 120 volt. WayteK wire (www.waytekwire.com), Del City (www.delcity.net), and RonThe Busnut (www.ronthebusnut.com) all have pretty good wire color assortments. Remember to use a large enough gauge wire to prevent voltage drop or overloading.  Jack
DrivingMissLazy
I would recommend that whatever wire you select that it be multi-stranded tinned copper. Some of the wire sold at places like Pep Boys is just bare copper wire without the tinning. The tin prevents the copper from corroding. From waaaaay back it seems like the UL standard is UL1019.
