Fast idle overrule
Fast idle overrule
Started by Jsrcaptain, May 25, 2021, 08:59:41 AM
Jsrcaptain
Can someone explain the theory of operation of the fast idle and fast idle overrule cylinders?
1972 MCI MC5B, 8V71 NA
Baraboo, Wisconsin
lostagain
When you turn on the fast idle, a solenoid (Skinner) valve applies air pressure to a cylinder that pushes on the fuel lever on the governor. It also applies pressure on an other cylinder that limits the amount the fuel lever can move. That is where you can adjust the desired rpm of the fast idle, usually around 1000 to 1200. The fast idle is interconnected with the parking brake, so it only works when the parking brake is applied.
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
