Bus Heat
Started by Kenny, March 01, 2007, 04:42:05 PM
Kenny
When it comes to heating using a diesel fired unit such as Webasto, Proheat, Aqua Heat, Espar etc. I've noticed that Aqua Heat offers a complete unit including reservior, pumps controls, valves, etc all included in a single unit. Others offer just the burner unit w/pump. Of you fellas out there, who has pieced their systems together and who has bought a complete unit? When piecing together, who's valves, pumps, heat exchangers, controllers, etc have you used? Can't make up my mind on which way to go.
Kenny
1941 and 1945 Flxible - South Lyon, Michigan
H3Jim
I pieced mine together because my bus came with an Espar unit.  I bought all the rest of the stuff from Dick Wright. 541-744-4333.  Its probably better to talk with Dick than with Jason his "right" hand man.
This had the added advantage of being very space efficient. The aqua hot comes in a metal box that you put in a bay.  If you buy separates, you can distribute the components to fill the odd nooks and crannies.  By doing this and other things I was abe to use only one of my three bays for utility stuff, and still end up with 2 full open bays.
Having said that, I have also found David Haynes, who sells complete systems (800-685-4298 x127) to be exremely helpful even if you don't buy from him.
Jim Stewart
Ross
I pieced a Proheat together.  I get domestic hot water from a flat plate heat exchanger and heat from two baseboard zones.  Each zone has a zone valve controlled by a single digital thermostat.  There is about 35 feet of standard Lowes baseboard and it heats the bus to 70F easily when outside temps are in the single digits.  The Proheat is also in the tank bay, so that bay stays above 50F in single digit temps.  I'm fulltime in the bus and this Proheat is by far the best money ever spent on the bus.
Ross
kenny,a lot of high end buses are using the oasis system in their conversions i know they are a marine unit i don't much about them but they look nice
akbusguy2000
lloyd
Heh Ross what is the BTU rating of the Pro heat. What did you use for the baseboard heat exchangers?
Ross
Quote from: lloyd on March 01, 2007, 07:09:37 PM
The BTU rating is 45K.  I used the run-of-the-mill off-the-shelf baseboard from Lowes.  Nothing special.  It was $7 per foot.
Ross
