Help identifying part
Started by hunter97321, June 24, 2020, 01:48:07 PM
hunter97321
I just started working on my bus (inherited 1965 Silver Eagle) . I have started it but I am having problems with not building air enough to turn off the alarm. It seems to stop around 50lbs. This part is leaking air. I took it apart and it seems to be some kind of pressure regulator / bypass. the rubber in the bottom is hard and looks like it needs replaced. I don't know what it is so I can't buy a new one.
LOL we have no idea what it is either without a photo or number
hunter97321
hmm I thought I attached the photo in the message. Thanks for the heads up
hunter97321
Apparently I needed to resize it.
That is a pressure protection valve it should have a tag for the PSI rating they are not exspensive 20 bucks or less at NAPA or a truck supply
hunter97321
97321 is that your zip code if so Paul Lawry  (Dreamscape)a 01 Eagle owner lives in Albany and knows Eagles
hunter97321
Yes it is. I think he is the person that sent me some manual information years ago, When I initially acquired the bus but then life got in the way and I wasn't able to work on it.
