Coolant leak series 60
Started by 6805eagleguy, February 29, 2020, 03:22:22 PM
6805eagleguy
Starting to fill coolant, it is coming out of oblong hole on the side of water pump against the block.
I found a picture of a water pump online with this hole, so I know it is supposed to be there...
what is the purpose of the hole?
1968 Eagle model 05
6805eagleguy
Http error 500 is what I get when I try to load pics
1968 Eagle model 05
blue_goose
You will need to rebuild the pump or replace it.  The hole lets the water out instead of going in the engine when the seal goes bad.
Jack
6805eagleguy
Replaced with a rebuilt pump, solved problem
1968 Eagle model 05
