Detroit Diesel Coolant....how to test its condition and etc.
Started by Sojourner, February 23, 2007, 08:59:22 PM
Sojourner
This is downloading of "Detroit Coolant Selections" brochure.
This addition to your engine manual....many of our "coolant" posts are answered.
http://www.detroitdiesel.com/Public/brochures/7SE298.pdf
On page 20 to 21 (22 to 23 PDF) discuss about "SUMMARY OF COOLANT RECOMMENDATIONS"
Also when to replace coolant after submitting the sample in a DDC Power Trac Coolant Test Bottle.
FWIW
Sojourn for Christ, Jerry
plyonsMC9
Good evening Jerry,
Thank you for this post.  You always have such good stuff for us.  Keep the 'em coming!
I have been running Fleet Guard - I probably should check the label - just to make sure...
Sojourn for Christ, Phil    ;D
Sojourner
Thank you kindly Phil!
This SCA additive is only apply to wet sleeve diesel engine.
I believe only 2-cycle DD has dry sleeve are 6-71 & 8-71 bus series. 6-92 & 8-92 are wet sleeve as well most modern diesel.
So "dry-sleeve" can use regular glycol antifreeze such as gasoline engine.
FWIW
