My bus needs a diaper
Started by Scott & Heather, November 04, 2019, 02:28:56 PM
When you driveway surf with a two stroke...
Whatever it takes...
Happy coaching!
Buswarrior
Jim Eh.
Great to "hear" a NICE neighbor story once in a while.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
DoubleEagle
Scott, those block stacks supporting the bus do not look stable. The one on the driver side looks like it's leaning. With the weight reduced on the drive wheels, the wheel chocks might not keep the bus from sliding back.  ::)
Walter
Dayton, Ohio
The bus wasn't aired down so the levelers were just sitting there leaning over. It's solid as a rock now. My brakes are applied too and air system drained. Been there done that.
DoubleEagle
That's good, I would really not like to hear that the bus squashed Heather.  :o
Walter
Dayton, Ohio
Utahclaimjumper
While she was cleaning the bottom of the coach??>>>Dan  ::)
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
Lol. You guys are nuts. We don't clean the bum bum of the bus. Just ain't worth it for us. It'll never rust and it'll never stay clean.
Utahclaimjumper
Look at Greyhounds on the road,,, they don't clean them either.>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
dtcerrato
When ours is on the pit we clean up the rear & bottom a bit. It always help to remove gravel from loose roads...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
It is harder to set fire to the engine room, if there is no build up of greasy stuff.
A rough going over periodically is good maintenance.
No toothbrushes or polish needed, unless you have time and OCD...?
Happy coaching!
Buswarrior
Detroit's don't need to leak here is one I rebuilt new seals and gaskets not a drop even from the air box drains
Utahclaimjumper
 By the looks of the paint on the exhaust pipes,, it hasn't been run either.>>>D
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
paint in the pully grooves...
tough crowd!
He has about 700 to 1000 miles now I think if they leak they leak out of the gate and air box drains leak on first start up,I don't mind tuff crowds the pipes are coated with prime and painted he has no leaks and boost is 22 lbs ,anyways if it does leak I will repair the leak Dan for free
