Installed a slobber tank
Started by David Anderson, September 05, 2019, 04:21:19 PM
David Anderson
My Houston Metro bus had the slobber tubes plumbed to the back of the muffler.  The barbs were sort of soldered into the muffler skin and in lousy shape with oil dripping on the back of the muffler.  Messy, I never liked it.  I searched the files on BCM and many of you did the little PVC cylinder with barb taps, drain, and air vent.  I did that today for my slobber lines, mounted it on the engine rail out of the way of everything, and I spent about $25 for parts.  I try not to idle much at all, so it shouldn't catch much.  Hopefully a bit cleaner ;D
David
Iceni John
When I made mine, I used a Costco cranberry juice bottle inside the rear bumper with two nylon elbow barbs in the cap for the lines from each airbox drain;  the last few inches of each line are clear plastic so I can easily see exactly how much each side is slobbering (sorry, Geoff!).   High tech it ain't, but it does the job admirably.   I think I've got less than $5 in my setup!
2kW of tiltable solar.
If someone wants to install one, but doesn't want to make their own,Walker Air Sep makes a nice  one. Or can easily be dabbed with  a 18" section of 4 inch plastic pipe, 2 end caps, a vent and fittings and drain lines from air boxes, and a drain petcock.
I'm waiting for the grumpy "it's not a slobber tube" comments to arrive. Lol.
I use the front cross member on the engine cradle for a older Eagle for air box drains
If you don't want to do an fyi, here is theirs:
https://www.walkerairsep.com/product_detail.asp?id=565
Also gives you and how to make one. If I had a Prevost, I would use this one instead of some home built one.😁
Geoff
slobbering
"Slobber"
Learn to pronounce
nounslobbering
/ˈsläbəriNG/
Learn to use properly
noun
the condition of having saliva dripping from the mouth.
"slobbering can be a sign of teething"
adjective
characterized by saliva dripping from the mouth.
"a large slobbering dog"the condition of having saliva dripping from the mouth.
adjective
Can't find it in my dozen Detroit Diesel manuals.
There, I did my duty.
Geoff
Geoff
'82 RTS AZ
More like a seeping wound? Post nazel drip?
DoubleEagle
More like a Saint Bernard thinking about food.  ;D
Walter
Dayton, Ohio
Geoff
Seriously, oil coming out the air box drains on a 92 series is usually from weak oil control rings on the pistons.
Geoff
'82 RTS AZ
Dave5Cs
Oh Geoff are you just, Teething us,LOL  ;)
Geoff
That's a good one, I have no teeth so I slobber when I eat popcorn!
Geoff
'82 RTS AZ
Cracks me up y'all are so worried about a catch can. I have more oil seeping out of every other orifice, seam, and gasket on my engine than I get coming out of my airbox drains lol. Just consider it undercoating for the toad and dust control for the road.
dtcerrato
Dan & Sandy
North Central Florida
PD4104-129 since 1979
