MC8 Muffler
MC8 Muffler
Started by tninov8r, August 03, 2019, 02:00:24 AM
tninov8r
Does anyone know the correct Donaldson, or equivalent, muffler # for a MC8? Any success stories?
1961 GM 4106 Custom Coach Conversion
1967 MC5A Custom Coach Conversion
1976 MC8 Custom Coach Conversion
Gary Hatt - Publisher BCM
For what its worth, my mechanic has removed the stock MC7/8/9 mufflers on 2 buses recently and knocked the guts out of it and then welded them back up and owners have reported they run much cooler.
My Series 60 was overheating and the same mechanic removed it and replaced it with a Resonator and my bus runs much cooler too.
The stock muffler is quieter which is kind of important when you have 40 - 50 passengers on board and driving thru big cities and when the bus is relatively new, but once the radiators start getting restricted, things start heating up and a restrictive muffler works against you in a bus conversion.
Something to think about before you order a replacement.
Or if you really want a stock muffler, you can run with your back doors open when thru Arizona in the summer like I used to do.  ;D
Gary
1999 Prevost H3-45
edvanland
Gary I am so glad Joe cut my muffler off and we put on the resonator. Our MCI 7 with 8V92 runs so much belter. Less smoke under power, doesn't bog down on hills like it used to, runs cooler and just all around better. I wish I would have known and done that 17 years ago. Thanks for introducing me to Joe
Ed Van
MCI 7
Cornville, AZ
Donaldson style 5 is inlet and outlet on the same end, MCI is an odd size outlet 4.25" I think, I used a M120131 which is 5" in and out, resonator, with a turbo engine, the same size but a muffler is M120176.  It is significantly smaller and lighter than the stock MCI muffler but with a little fab work on the mount it works just fine, sits in the original spot.
tninov8r
Have found a local supplier for the M120131 Donaldson MUFFLER for our MC8 - does anyone know if this muffler will work/fit in our MC5A as well? Stock ID was 8b-20-1. Thanks.  :)
Many people are tearing out their MCI mufflers and installing straight-thru Resonators instead. The stock mufflers hold back too much air causing overheating especially when engines get old.
Others are splitting them open and cutting out all of the baffles to it can breathe better and welding them back up.
They will be a bit louder without a standard muffler but the resonator is not that loud and lets the engine breath a lot better.
1999 Prevost H3-45
I took off the giant transit bus muffler (was very quiet) and replaced it with the Donaldson 120131 10x15 oval 5" same side in and out. It is a high flow turbo muffler. If you look inside, it is empty except for the baffle that separates the right from the left. It puts out a nice tone-lets everyone know you're there, but not too loud. No need for an additional resonator. Highly recommend this muffler. I'm using the same muffler on my truck conversion. Good Luck, TomC
Yeah...it is not very loud from 35 to 40 feet upfront.
Jim Eh.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Glennman
This sounds like a great idea to help with hills and overheating. What is a resonator? is that simply a tail piece add on?
DoubleEagle
It's a muffler with a straight-thru design, usually with a perforated center tube with fiberglass stuffed around it, like the old hot rod "glass packs". It reduces the back pressure while making the exhaust sound more robust (or noisy in some ears).  ::)
Walter
Dayton, Ohio
Great...
More old buses driving around making a hell of a racket.
And that won't cause the hobby any trouble with the authorities or public opinion?
Do we really need more attention?
If your bus overheats, fix the cooling system.
Happy coaching!
Buswarrior
Some call it "noise".  I am a Bus Nut, I call it "music".  And to use Jakes on top of that?  WOW!  ;D
When idling thru a campground, a Resonator does not sound that much louder than a regular muffler if you keep off the throttle.
I would much rather listen to a bus than some of those "noisy" Honda cars out there with "stock" mufflers that drive me nuts.  >:(
I used to have a Harley in a previous life.  I guess people would hate me for driving that too.   ::)
1999 Prevost H3-45
Some of us hate you for all the noise. 🤨
DoubleEagle
If we have resonators we would still be much quieter than a Harley with straight pipes with the radio turned up loud so that everyone can hear it over the pipes.  :o
Walter
Dayton, Ohio
