Where do I find the serial number? 8v71n
Started by 6805eagleguy, March 20, 2019, 08:01:22 AM
6805eagleguy
Trying to figure out if I have a 2 or 4 valve head, the engine is not in the bus, I have looked all over but can't find a serial number any where... :-\
To find out what my injectors are, I decided to pop off the valve cover.  Unscrew the two knobs, and it comes right off, right??   NOT!  I didn't force it, assuming its just stuck from many years, but maybe there is a secret?!
1968 Eagle model 05
Bill Gerrie
Here is the page from the book showing where to find it.
The air box drain is probably covering it on the left side under the drain,if that is a old Trailways they were on a round tag on the oil pump with Trailways numbering a  68 model will be a 4 valve head for sure
6805eagleguy
Ok sorry for the late reply...
The valve cover finally came off, It was just a matter of gently coaxing it till it broke loose from the rubber seal.
So i have the n65 injectors...  from what i have read that is 318 hp?
And no numbers anywhere, must be a railways that the tag fell off... :P
I guess i don't need the serial number after all ;D ;D ;)
BTW this engine is for sale:  http://eagles-international.net/forums/viewtopic.php?f=6&t=4848&sid=b0f9c47635242c52b8df39460424990c
1968 Eagle model 05
