Macerator bathroom
Macerator bathroom
Started by richardkillmon, January 02, 2019, 05:07:16 PM
richardkillmon
Hello all and happy new year,
I'm rebuilding an MCI 5B 1976 bus and have completed all the insulation and the panels replaced.
I'm thinking of installing a macerator toilet system in the bus.
What is the best toilet to use?
Is the system worth it?
Rick
1976 MCI 5B challenger MT-644
oltrunt
While I don't have a macerator toilet in my bus I do have a macerator after the black tank slice valve.  This allows me to empty my tanks with a short section of 5/8" garden hose rather than a 3" stinky slinky and even allows for uphill discharge--love it.  Jack 8)
Gary Hatt - Publisher BCM
I have a macerator toilet in my bus.  It chews everything up and spits it into my black water tank.
The advantage of this type of toilet is that if you do not have a straight drop into the tank you can pump the sewage horizontally for some distance as I have to in my bus.  The other advantage is that when you dump your black water tank it is very easy as there are no clogs.
The disadvantage of these toilets is that they do not flush completely without using a lot of water.  There is always residual "stuff" left floating in the toilet.  Yes, you can clean it completely but it may take more than twice the amount of water than a regular drop toilet.  Also, if you lose power, you cannot flush your toilet.  They are also a bit more noisy than a regular toilet, but not that much.
1999 Prevost H3-45
Dave5Cs
Masadisposerator The only way to fly. 1/2" to 3/4"garden hose will do up to 145 ft... :)
There is this big misconception that your black tank has to be directly under the toilet. My bus has the black tank mounted in the center with about a 4ft ABS 3" feeding it. Granted I have to use a bit more water, but then I have more water in the tank at flush out (45gal).
My truck I have a run that goes to the right then slopes down about 8ft to the tank 2ft below the toilet. I too tossed around using a Macerator toilet, but there's is nothing more reliable than a gravity toilet. Good Luck, TomC
Fred Mc
My first camper had a mecerator toilet. It worked fine until it didn't. After I had "fixed" it I swore I would NEVER have another one-ever-never-ever. I probably don't need to tell you why.And I haven't.
Jim Blackwood
Nothing beats a straight drop.
Dave5Cs
yes actually a straight drop will end up with the almighty pile of poo that hardens a little at a time if you don't really clean out your tanks well every time.
Mine has a 6 inch drop and then turn and slops down for 2 feet and then drops in. I also have a 3" sewer cap and fitting on the top outside edge of the tank so I can use a sprayer to wash out the tank after it finishes dumping.
richard5933
Whether you have a straight drop from the toilet to the tank or a few feet of sloped pipe before the tank, you still can have problems with piles of poo building. Both of these setups will at some point drop things into the tank, and if enough water isn't in the tank piles will build.
We move quite often, not usually staying in one site for more than a few days. This keeps things in our tank mixed up pretty well. Doesn't hurt either that we have a combined black & gray tank, which means that we've always got a pretty liquid mix.
Geoff
Ok.  I have a house toilet with a straight drop into the 35 gallon black tank.  I use a 3" hose to dump with no problem, or a 3" marcerator pump and dedicated black garden hose for long distance dumping.  No problem with the house toilet, and no smell.
Geoff
'82 RTS AZ
crap mountains only happen when you skimp on the flush water.
windtrader
With the toilet directly over the tank, any poop hill can be gone with a strong blast of streaming water from a garden hose stuck in the open toilet drain.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Geoff
Quote from: windtrader on January 05, 2019, 02:38:10 PM
Sometimes people don't dump their black tanks for months and the contents can turn into clay.  That's when the RV places tell the affected person to dump a bag of ice cubes through the toilet and go for a drive on twisty roads.  They will charge you heavily if the have to pull the tank off to clean it up and put it back in.
Geoff
'82 RTS AZ
Add more fiber to your diet😏
dtcerrato
When hooked up to shore sewer we always hold the black tank and dump when needed if a long duration stay, or dump upon leaving, mountains don't build under liquid - at least in our black tank. We have a pair of 74 gal. - 1 black, 1 grey. Black dumps 1st, then we dump grey into black - that 3" blast from one tank to another will move mountains if there were underwater earthquakes...
Dan & Sandy
North Central Florida
PD4104-129 since 1979
