Slide Master Good or Bad
Started by scanzel, July 19, 2018, 05:08:40 PM
scanzel
Trying to get two slides for my bus and haven't been able to get any further response from Slide Master since June 25th, left vm msgs none returned after initial contact. Has anyone had experience with them good or bad. Even sent pictures of what I need, one for generator and one just basic for stuff.
Steve Canzellarini
Myrtle Beach, SC
1989 Prevost XL
Fred Mc
They are quite easy to make using 2" channel iron, ball bearings and angle iron. If you can't weld, the cut up the angle iron and channel and take it to a welder to weld together. Material will probably be under $100.
bronson
Probably does you no good but ickes rv surplus in montpelier ind had about 10 slide trays on display. They were $100 when i bought some a few years ago. Not heavy enough for gen. Love mine for  tools grill and misc.
Gary Bronson
1984-MCI-9
Mount Orab Ohio
windtrader
Quote from: Fred Mc on July 19, 2018, 09:24:30 PM
I'm with that. Fab them yourself, seems quite basic, custom size, saves mucho dinero too.
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
Jim Eh.
Doesn't std channel have a chamfer on the inside?
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Fred Mc
Yes, it does which aids in smooth easy sliding as the bearing edge only rides on the channel.
Gary Hatt - Publisher BCM
Check out "How to build a Slideout for a Generator" by Fred Hobe in the September 2013 issue to learn all about building your own.  Of course the size of the material will be determined by how big your generator is. All back issues are online for all subscribers to read 24/7.
1999 Prevost H3-45
