I come before you ashamed and embarrassed
Started by opus, June 15, 2018, 05:22:12 PM
opus
Ok, now that thats over with, this was allegedly [see what I did there, I made it sound like someone else did it] painted with a brush and rustoleum.  As you can see, it hasnt faired well, as expected....big mistake.  It was a temporary fix that has turned into disaster.  I want it off and back down to yellow [for now].
Ideas?  Sandblasting would be a little harsh and take off more than the stuff thats peeling.  Anyone ever use a one of those sand blaster attachments for a pressure washer?  It about will come off with just the pressure washer.
DominicM
I would suggest a 5000 psi pressure washer with a spin nozzle.
The spin nozzle will remove an coating that is not tightly adhered.
67 MCI 5A
I live in Nashville,  and Reside in my 5A in Big Spring TX for work at the moment,  Will update as I move around.
Soda blasting. The residue can be washed away with the rain. The new paint came off because the yellow wasn't prepped or enough to allow the new coat to adhere. They do make pre coatings that will allow minimum prep. One is XIM. Another is Zinzer alcohol based primer.
oltrunt
I feel you're pain!  My bus was brush painted with Air Force grey latex paint so it could be used in a movie about WWII Japanese relocation camps--that was 15 years before I bought it.  It took me 4 1/2 weeks using paint stripper a wire brush a scraper and a BUNCH of sand paper to get enough of the paint off  for a repaint.  At Mickey D's wages that is about $2700--nearly what the bus cost me.  The worst part was hand sanding to the original finish around every rivet.  And my bus is only half as long as yours--now I'll probably have nightmares.
On the bright side, my repaint is now 6 or 7 years old and still looks fresh.  Remember, your repaint will only be as good as the one under it. Happy sanding :D  Jack
opus
I've done enough of this to know about prepping.  Time and situation wouldnt allow it, I knew what I was getting into.  Re-painting is the least of my concerns now.
Soda blasting wont work for me because I have no access to a commercial sandblaster.  Its either going to be with a pressure washer and attachment or something else to do with a pressure washer, or it will stay as it is.
Jack, I surely dont have the ambition for that!!  30 years ago it would have been questionable too, lol!  However, should you ever desire a vacation in Montana......
lvmci
Take all the paint off, down to metal, it will look handsome...
MCI 102C3 8V92, Allison HT740
opus
That sure would be cool looking.  I've never seen a better bonded paint than a school bus.  I've seen how they bake it on.  I'm afraid the metal and paint are one.
Iceni John
Quote from: opus on June 15, 2018, 08:26:17 PM
Same here.   The original paint on my bus's aluminum body panels is never going to come off without a fight (I think it's structural load-bearing paint), but on the steel below the windows it can be persuaded to come off with some moderate aggression on my part.   On the fibreglass (sorry, fiberglass) it comes off easily, but that's only on the roof caps and front and rear ends.   When I repaint my bus I'll sand and degrease as much as possible while leaving the original paint in place, and only remove original paint from the FG.
2kW of tiltable solar.
brmax
On a cool 70-80 degree day, use some house wrap for run off gathering. With this apply on some strip eze type remover, or apply how ever to the recent paint coating.
Cover these small manageable areas say a 6 x 12' with plastic and tape this securely for awhile. This helps and although this works good it is still a better process in mild temperature weather as mentioned.
My idea ( scrape hell, put more stripper on ) and follow mfg. recomendations for applications and materials removed.
Good day
1992 MC9
6V92
Allison
DoubleEagle
Chances are pressure washing will take more off, but not all of it. Experiment with strippers on small areas, and then pressure wash again. The temperature and length of time the stripper is on will determine how easy it comes off without affecting the original yellow. Use weaker ones like citrus first. Using a brush is not embarrassing, but then, using a roller might be.  ;D
Walter
Dayton, Ohio
opus
I did the stripper thing...paint stripper that is.  It worked but made the yellow soft, plus RIVETS galore.  There will be no hand work done at all for this.  I cant do it, nor do I care to do it.  I'm thinking rat rod, lol.
It may not look great but rest assured, it is mechanically 110% with meticulous maintenance.
brmax
Great Work!
In the coming months when all the green is off, hire some youngsters to wash it 4 different times in this summer.  :)
The trick is that they can only use red scotch brite pads, 1 each and the real ones.
You couldnt get a better prep for rat rod dupont primer.
Rock On!
Floyd
1992 MC9
6V92
Allison
